JD 210 loader
/ JD 210 loader #1
KENSFM
MA
JD 2210 JD318 JD332
Did anyone install their own 210 loader? Just wondering how many quarts of hydraulic oil had to be added to your 2210 tractor.
Thanks, Ken
/ JD 210 loader #2
Didn't install my loader but when I installed the snowblower it took about 1/2qt. of fluid. Probably about the same as the loader would have taken.
/ JD 210 loader #3
The volume of all the lines and all the cylinders I would guess be around 2 quarts. I'd add a quart first then cycle and recheck. Make sure you cycle the arms and bucket serveral times to thier full extent to purge out all the air. Return the loader to the resting position then recheck your level.
/ JD 210 loader #4
I installed my own loader and did need to add "quite a bit" of oil. I also installed the snowblower and the loader took at least twice as much oil. My guess is that the blower (and quick hitch) took about a quart and the loader took about 2 quarts (but I didn't actually measure). I bought a gallon and I think I have a bout a quart (or maybe slightly more?) left. I cycled ALL the loader cylinders full length several times then added oil and went to work. After using it for about an hour to do some light snow pushing, I had to add another pint or so. So just cycling it a few times doesn't seem to do it.
Just keep an eye on the level glass and make sure you lower the TPH and the loader before you add oil. Also shut the tractor off and wait about 2 minutes before you take a reading. My dealer service man was here the last time I added oil and that was the procedure he recommended. The book says the same except it doesn't mention the short wait for drain down.
BTW - The dealer serviceman was on site to install the block heater. After holding the light for him and watching him work, I'm really glad I didn't tackle it myself! Even HE didn't have a metric wrench big enough to fit the heater and its a really tight spot to work. It only cost me about $52 and it seems that many of you paid almost that much for parts alone. He brought the new govenor cover (or whatever) too but he could see no reason to install it so he chose not to.
Dave
/ JD 210 loader
Installed my 210 loader yesterday had to add 2 quarts of oil to bring level to the correct reading. Thanks guys for the replies as dealer thought that what was in the tractor would be OK. /forums/images/graemlins/confused.gif Installation is quite simple if you read the manual. Wanted to do it myself as dealer has great prices but I think his service department is a little weak.
Thanks again and Happy Holidays.
Ken /forums/images/graemlins/smile.gif
2016 International WorkStar 7400 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2016 International...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
POWELL / COLE 6R RIPPER (A63291)
POWELL / COLE 6R...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
Dexter trailer axles (A61567)
Dexter trailer...
