JD 2030 Play in steering wheel
   / JD 2030 Play in steering wheel #1
awightman86
Grayling, MI
John Deere 2030
I have a John Deere 2030 tractor that has a lot of play in the steering. The tye rods are in good shape. Is there a way to adjust the steering to eliminate the play?
Thanks for any help that you can provide.
Allen
   / JD 2030 Play in steering wheel #2
Remove rear round inspection cover on clutch housing and be sure bolt(parts key #11) is tight and arm(parts key #9) is snug on tapered splines on shaft(parts key #7) Also check for looseness in bellcrank(parts key #2) in the center of frt axle.
   / JD 2030 Play in steering wheel #3
I second checking the bellcrank. My 2030 needs the bearing on it replaced. On my "to do" list.
1981 AZTEC SKINNY NECK 31 FOOT FLATBED (A53843)
1981 AZTEC SKINNY...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2019 BOBCAT S770 SKID STEER (A52705)
2019 BOBCAT S770...
