JD 2030 Play in steering wheel
   / JD 2030 Play in steering wheel #1
awightman86
Grayling, MI
John Deere 2030
I have a John Deere 2030 tractor that has a lot of play in the steering. The tye rods are in good shape. Is there a way to adjust the steering to eliminate the play?
Thanks for any help that you can provide.
Allen
   / JD 2030 Play in steering wheel #2
Remove rear round inspection cover on clutch housing and be sure bolt(parts key #11) is tight and arm(parts key #9) is snug on tapered splines on shaft(parts key #7) Also check for looseness in bellcrank(parts key #2) in the center of frt axle.
   / JD 2030 Play in steering wheel #3
I second checking the bellcrank. My 2030 needs the bearing on it replaced. On my "to do" list.
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
HANGCHA CPCD25-XW98C-RT4 STRAIGHT MAST FORKLIFT (A51406)
HANGCHA...
