JD 2030 hyd problems
/ JD 2030 hyd problems
This is before the pcv with the steering line plugged
/ JD 2030 hyd problems #13
I recommend unlocking nut & turning(CW) stroke control valve adjusting screw into hyd pump while monitoring hyd gauge. Stand-by pressure should be 2250-2350 psi.
Ok. I'll try that and see if it will increase. Thanks
/ JD 2030 hyd problems #15
Do you think that the lower pressure is the reason why the 3pt quit working? Or are they different problems?
Just to keep things simple, my thought is that 1000 psi is still plenty to make the 3pt work. I'd not mess with compensating for pump wear until figuring out the 3pt problem. It sounds to me like you still have an internal leak back there.
rScotty
/ JD 2030 hyd problems #16
rScotty
If pressure control valve is functioning as designed rockshaft & scv's should stop functioning when stand-by pressure dropped below 1700 psi.
/ JD 2030 hyd problems #17
Really? Well, that just proves what I said earlier in the thread .... that a person like myself can understand open center hydraulic systems well, and still not know the first thing about Closed Center systems like many John Deere ag tractors use.
For comparison, in an open center system, there is no pressure control valve and no lower limit at which a system just stops functioning. As pumpn pressure drops in an open center system, the cylinders simply lose force at a the same rate until finally there isn't enough force to overcome gravity.
I haven't measured it, but that's probably somewhere around 100 psi for 3pt arms.
I did measure one open center FEL, and that one took about 600 psi just to lift an empty loader bucket.
rScotty
Well I adjusted the stroke valve an maxed it out and it still stayed at1400#
I did pull the spring assembly out an measured it a per manual. It still at full measurement. The valve still looked good also.
2018 Bobcat T770 (A60462)
2018 Bobcat T770...
2016 GMC Seirra Denali 1500 4x4 Crew Cab Pickup Truck (A60352)
2016 GMC Seirra...
2024 Linx EQ07020TS (A60463)
2024 Linx...
2007 MACK CHN613 DAY CAB (A59906)
2007 MACK CHN613...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2020 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2020 DRAGON 150...
