JD 2025R and compairables
   / JD 2025R and compairables #11
FYI... The Mahindra max is built by Mitsubishi for Mahindra. In my opinion that's a plus.
In this size, most players now offer a nice unit with a 5 year warranty, except Kubota @ 3 yrs and Kioti @ 4 years.
You can make your choice by personal comfort and preference, they'll all be close enough.
   / JD 2025R and compairables #12
Go drive a 2025R and then drive a Kubota B2601 or B2650. You'll see a world of difference. I was 100% convinced that I'd be buying a Kubota when comparing those size tractors.
   / JD 2025R and compairables #13
I agree^^^^
They are all good and very comparable. Spend a little time to pick one that you like the best. Others may pick something different but these are so close in abilities that your satisfaction with the tractor you pick is the most important thing to consider.
   / JD 2025R and compairables #14
There are a lot of Max's out there, for a reason. A plus is the Mitsubishi manufacture.
Thanks guys I am taking it all in. The closest Massey dealer did not have ANY 1700 series units. He had Massey and Mahindra 1533 the smallest units on the lot. I like the 1533, but I think it is to big for me. So the search continues. B.
   / JD 2025R and compairables #16
Lindenbruce , can you clsrify:
1. Masseyndealer didn't have any gc1700s or didn't have any 1700s ???
2. Will you look to amother Massey dealer ?
   / JD 2025R and compairables #17
Just curious Bruce, why did you rule out Kubota right off the bat... do you just not like the color? I'm not stuck on any brand but am interested why you are against a particular one.
   / JD 2025R and compairables #18
if the 1533 Mahindra is too big, check the 1526. It's smaller than the 1533, larger than the Max, the same size as the older 3016, and an excellent machine.
   / JD 2025R and compairables #19
I'm not a fan of the 2025, on paper anyway. The old 2 series had 3 models, 2320, 2520, and 2720. with the redesign, JD dropped it to 2 models the 2025 and 2032. The 2025 is more comparable to the 2320 than the 2520, except for the slightly larger engine. The 2032 is ver much like the 2720. Its slightly bigger, by about 2 inches if I recall, heavier by 300 lbs or so, and had nearly twice the hydraulic flow. both of the JD 2 family tractors have a 2 speed hydro, most other offering in a similar class have 3 range hydros, which will give you better options for different types of work.
I'd take a hard look at the Kubota B series, the 2650 is a great package, or even the 2601 in a slightly smaller size. As Axlehub mentions, the Massey 1726E will get you good hydraulic flow, 3 range hydro, and more weight, which is an advantage for loader work or pulling a box blade.
I'm not familiar with the mahindra or ls models, and even kioti, but there are plenty of folks who are, and I am sure they will chime in soon!
Good luck in your search.
Ya, and they even inherited all the ongoing issues of the old 2 series. Just read all the forums. Especially Green talk. I wasn't a Kubota fan either, until I passed on green and bought one. Not a single issue.
And ya.....JD offers a 6 year warranty now. looks good on paper but ask the dealers about all the claims that get denied, LOL.
   / JD 2025R and compairables #20
What issues are you talking about?
2016 CAT 980M WHEEL LOADER (A50854)
2016 CAT 980M...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2011 FORD F-250 (INOPERABLE) (A50854)
2011 FORD F-250...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2015 FREIGHTLINER M2 (A50854)
2015 FREIGHTLINER...
