jd 1910 airseeding carts
/ jd 1910 airseeding carts #1
wazza
has anyone had water getting into distribution systems.??
/ jd 1910 airseeding carts #2
Welcome, and you are probably thinking you are being ignored. Truth of the matter is likely you are, because likely no-one here is using the cart you speak of and therefore do not have a problem with water getting into the system in the cart they do not have. The question you have is specific, and not likely to pertain to this forum, or its members, which is mostly about compact utility tractors.
Hope we are not coming across as being rude, but you need to seek a different forum for the answer or head back to your Deere dealer.
Sorry.
What tractor do you pull that 'cart' with? Any thoughts as to why water would be getting into the distributuion systems in it?
/ jd 1910 airseeding carts #3
He probably pulls the planting cart with a large row crop tractor like a JD 8400 or so. Big ag equipment that none of us have here. I see it at work but I am not a tech so I can't answer anything techinical about this air seeder.
2024 Teagle Tomahawk 8500 (A63688)
2024 Teagle...
2017 Buick Encore Preferred SUV (A61574)
2017 Buick Encore...
2005 Butler pole trailer (A62679)
2005 Butler pole...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
UNUSED WOLVERINE FORK FRAME (A64281)
UNUSED WOLVERINE...
