JD 185 Hydro Start/Run problems
/ JD 185 Hydro Start/Run problems #1
hosickjg
Ontario
John Deere 185 Hydro
I'm having problems with my 1989 JD 185 Hydro. Here's the symptoms:
Starting Problems:
-The only way to start it is to pull the throttle/chock on full and let it turn over 30 or so times until it floods
-Then put the throttle down to a dead idle and it will sometimes then start at a dead idle.
-Then I have to work the throttle up SLOWLY until it gets to operating speed.
-If I move the throttle even a tiny bit to fast it dies out and I have to go through the starting steps again.
-Once up to operating RPM it runs great and can be worked in tall grass or with the blower on with no issues
Things done:
-I have taken apart the carb and cleaned it with carb cleaner and compressed air. It was very clean already and doing so didn't change anything.
-I've checked the spark and it appears blue and healthy
-Compression is fine
Suggestions?
Common issues with these tractors that gave the same result?
2017 Chevrolet Impala Sedan (A64194)
2017 Chevrolet...
Truck Tool Box (A65640)
Truck Tool Box...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
(2) New 27X8.5-15 turf tires in John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 27X8.5-15...
Golf Cart (pictures to come) (A62679)
Golf Cart...
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
