JD 1530
/ JD 1530 #1
Attica
Knoxville, IA
JD 1530
I am trying to change the PTO oil seal and I am having a little trouble getting the cover off. I tried a gear puller but there isn't enough of a lip on the left side. I was wondering if I'm doing it wrong or is there an easier way.
Thx
Attica
/ JD 1530 #2
You need to hold shift lever(parts key 1) forward when pulling rear pto shaft out of tractor so shift collar(parts key 8) doesn't fall off pto input shaft.
/ JD 1530 #3
Tap the PTO SEALHOUSING LIGHTLY WITH A HAMMER And drive the frontwheels in a ditch then you do not have to drain the tran oil Then pull out
/ JD 1530
Tap the PTO SEALHOUSING TIGHTLY WITH A HAMMER And drive the frontwheels in a ditch then you do not have to drain the tran oil Then pull out
Thx. I was going to try that but I was afraid I might crack it.
2009 CATERPILLAR CP44 PADFOOT ROLLER (A65056)
2009 CATERPILLAR...
2018 JOHN DEERE 350G LC EXCAVATOR (A65056)
2018 JOHN DEERE...
1999 INTERNATIONAL (INOPERABLE) 4900 (A67714)
1999 INTERNATIONAL...
2007 (INOPERABLE) INTERNATIONAL 9900I (A67714)
2007 (INOPERABLE)...
TRIN  BOTTLE TRAILER (A67714)
TRIN BOTTLE...
2014 HIPOWER 310 Generator (A67714)
2014 HIPOWER 310...
