JD 1530 PTO Clutch Engagement
   / JD 1530 PTO Clutch Engagement #1
newbiefarmer
Savannah
None Yet
I've recently acquired a 1530. It has the independent hyd. PTO option. I have been running a 6' bushog around the property and without a ton of experience have some questions about the performance of the PTO clutch.
1) It takes several seconds (3-5s) for it to begin turning the PTO (even at near idle), without any load on the bushog.
2) Under heavy load, the PTO will stop turning until I raise the implement. It does take a big load though (I would estimate at least 60-70% of available horsepower) for this to happen
Are these behaviors normal?
   / JD 1530 PTO Clutch Engagement #2
NO. How long since hyd filter was changed & sump screen(parts key 30) was checked/cleaned. Then I'd suggest to check trans pump pressure. It should be around 165 psi.
Not sure on when services last, I will R&R filter/screen. Any hints on where to tap into for pressure check?
   / JD 1530 PTO Clutch Engagement #4
   / JD 1530 PTO Clutch Engagement #5
I think an independent hydro PTO was an option, not sure though. If not the PT clutch is slipping.
   / JD 1530 PTO Clutch Engagement #6
You can check trans./pto clutch pressure on shifter cover under sheet metal cover that the 2 gearshift levers protrude through.
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
1994 Fiat Allis 65-B Motor Grader (A52384)
1994 Fiat Allis...
2011 Superior Trailers of Georgia Trailer, VIN # 4M8FZ1629BD000279 (A51572)
2011 Superior...
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2021 Ford F-250 XL...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
