JD 110 TLB loader bucket/joystick problem
/ JD 110 TLB loader bucket/joystick problem #1
courtney chalker
john deere 110 TLB
The joystick on my 110 TLB will move bucket up and down but I can't get bucket to roll. Lock lever is in unlocked position, but when I twist joystick left or right, acts like it's locked. Any suggestions?
/ JD 110 TLB loader bucket/joystick problem #2
I had the same kind of problem with my 4600 when it was new. It turned out to be the linkage at the bottom of the joystick and the top of the valve. I can't quite remember exactly but I needed to do some tack welding for the fix. It wasn't fun getting everything apart and back together. Good luck
MD3
MD3, thanks for info. My Gehl skid loader has T-Bar controls and you have to twist left or right to curl the bucket up or down. I was trying to twist JD joystick and turns out all I have to do is push or pull left or right to curl the bucket. I feel like an idiot, but I'm glad it was just operator error. Thanks again.
/ JD 110 TLB loader bucket/joystick problem #4
same problem here...would was your solution ...thank you
