Backhoe JD 110 LTB, 2003
/ JD 110 LTB, 2003 #1
watco
Woodstock, VA
JD110 TLB
I have a flashing light, code "long short, long short" Creep Control... engine speed sensor replaced, potent adj for creep control, potent for throttle control adj, all connection that can be serviced has dilectric grease installed, all filters changed and fluid... light comes on even if you let tractor warm up, then the creep wont work! the temp gage for the hydaulics doesnt seem to work (think maybe). some times tractor will go days with no flashing light! Help with any suggestions!!!
/ JD 110 LTB, 2003 #2
Lets try to get some more info. what is the serial # of your tractor, the electrical changed through the years of the TlB 110.
Do you have a service manual?
Does the machine run ok if you are using the forward and reverse foot control?
Do I understand correct, you replaced engine sensor,creep control pot,throttle pot.
There are a few TLB 110 owner on here and they have helped me in the past, I am sure if we can get the facts we will be able to give you ideas to help you.
/ JD 110 LTB, 2003
Lets try to get some more info. what is the serial # of your tractor, the electrical changed through the years of the TlB 110. (2003)
Do you have a service manual? (yes)
Does the machine run ok if you are using the forward and reverse foot control? (yes)
Do I understand correct, you replaced engine sensor, (adjust) creep control pot, (adjust) throttle pot.
year 2003
service manual, yes.
runs fine
replaced engine speed sensor, adjust creep pot, adjust throttle pot.
/ JD 110 LTB, 2003 #4
The creep pot is connector X29, I believe pin A (black 550wire)is ground, C(orange 679wire) is supply and B(white 689wire) is the signal back to the HST controller pin J3. I would first check the connectors and wires. Since the machine runs with foot control the output for forward and reverse are ok. The inputs are what is left, could be the supply but this supply is shared with the other pots. Ground is the same.
X29 connector and wires.
HST controller white wire on J3.
HST controller.
The above are possible.
Is it possible you are doing something different when using the creep than normal. maybe seat switch.....other switches safety.
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2004 Ford F-550 Single Cab Flatbed Truck, VIN # 1FDAF56P94EC72605 (A65563)
2004 Ford F-550...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2012 Ford F-250 6.7L Diesel, 4WD (A62679)
2012 Ford F-250...
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
ALUMINUM TOOLBOX (A64277)
ALUMINUM TOOLBOX...
