Backhoe JD 10A Backhoe
/ JD 10A Backhoe #1
Lawnjocky
Central Illinois
JD 3520
I saw a 10A backhoe advertised for sale and I was wondering how hard or expensive it would be to make it fit my JD3520. Is it even possible to put on my tractor? Thanks
/ JD 10A Backhoe #2
Hi Lawnjocky;
With welding almost anything is possible. Get a subframe for the 3520 and fabricate mounting brackets for the backhoe.
The 10a might be a bit large though.
{disclaimer} I'm no expert, nor did I recently sleep at a Holiday Inn....:D
good luck....
/ JD 10A Backhoe #3
the 10a was the hoe for the 5000 series tractors. I would lt it go.
/ JD 10A Backhoe
I had read that the 10A was for the 5000 and thats what I was concerned about. I didn't know if the back hoe was to big for my tractor. I wouldn't mind doing some welding if it will work when I'm done. If my 3520 doesn't have the size, flow capacity, etc, I don't want to waste a lot of time and money on the idea.
Thanks for your help
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
2021 KLX 300 Motorcycle (A61166)
2021 KLX 300...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
UNUSED WOLVERINE SB-12-72W 72" HYD SCREENING BKT (A62131)
UNUSED WOLVERINE...
PALLET OF BRIGGS & STRATTON SNAPPER PUSH MOWER (A62131)
PALLET OF BRIGGS &...
CATERPILLAR GC25K STRAIGHT MAST FORKLIFT (A62129)
CATERPILLAR GC25K...
