JD 1070 Oil viscosity
   / JD 1070 Oil viscosity #1
sodly
jd
I am changing oil in a JD 1070 for the first time for a relative. Can anyone tell me the recommended viscosity and capacity? I presume 15w-40 but want to be sure. Unfortunately, I don't have a manual handy. Thanks!
   / JD 1070 Oil viscosity #2
I would presume it has a dipstick or a sight glass. Add a couple quarts and see where the level is at. Easy Peasy.
Far as oil goes, I don't have clue one about JD but if it's a gas motor instead of Diesel, any motor oil will do. If it's a diesel then I'd use 15-40 or 5-40 Rotella T6.
   / JD 1070 Oil viscosity #3
Instead of winging it here is the link you can download the manual for free from John Deere.
I have it in PDF but it's too large to attach. If you have trouble downloading it I wouldn't mind at all emailing it if you think your email can handle it.
15W40 for around zero F to 104F. 5.6quarts capacity change with filter.
   / JD 1070 Oil viscosity #5
Zee best would be M1 0w30 ESP like I just put in the JD 2025R in place of the VW Castrol 5w30 that I'd been using. Next best (and less expensive) is 5w40 T6 someone else mentioned. Downhill from there. 15w40 is probably about the worst other than a plain 30w.
378539 (A51573)
378539 (A51573)
2019 KENWORTH T880 (A52472)
2019 KENWORTH T880...
2017 FORD F350 (INOPERABLE) (A52472)
2017 FORD F350...
2020 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (INOPERABLE) (A52472)
2020 PETERBILT 567...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
Informational Lot - Financing (A53472)
Informational Lot...
