JD 1070 intermittent starting problem: Starts then dies.
   / JD 1070 intermittent starting problem: Starts then dies. #1
Rodent
Victor, NY
John Deere 1070
My JD 1070 will generally start up OK and sometimes stays running good. Intermittently it will start and then 'die' after a few seconds and frequently not start or run normally unless left off for several hours. Have replaced the fuel filter/water separator beneath the gas tank but no improvement.
Any clues or guidance to cause and repair much appreciated.
Thanks/Rodent.
   / JD 1070 intermittent starting problem: Starts then dies. #2
I have a PDF of the Deere Tech manual you're welcome to if you want it, shoot me your email
Joe
   / JD 1070 intermittent starting problem: Starts then dies. #3
There is another filter up front in the engine compartment on the right lower side (looking forward). I believe the front filter is a water separator. You might want /need a band type wrench to remove the filer cap. Turn off the rear filter shutoff valve before you check this one.
2016 BOBCAT T590 SKID STEER (A51242)
2016 BOBCAT T590...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
2020 ROLLINS 26' FG GOOSENECK TRAILER (A51243)
2020 ROLLINS 26'...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
Payment Instructions (A47384)
Payment...
2023 Jeep Gladiator Sport 4WD SUT (A50324)
2023 Jeep...
