JD 1070 intermittent starting problem: Starts then dies.
   / JD 1070 intermittent starting problem: Starts then dies. #1
Rodent
Victor, NY
John Deere 1070
My JD 1070 will generally start up OK and sometimes stays running good. Intermittently it will start and then 'die' after a few seconds and frequently not start or run normally unless left off for several hours. Have replaced the fuel filter/water separator beneath the gas tank but no improvement.
Any clues or guidance to cause and repair much appreciated.
Thanks/Rodent.
   / JD 1070 intermittent starting problem: Starts then dies. #2
I have a PDF of the Deere Tech manual you're welcome to if you want it, shoot me your email
Joe
   / JD 1070 intermittent starting problem: Starts then dies. #3
There is another filter up front in the engine compartment on the right lower side (looking forward). I believe the front filter is a water separator. You might want /need a band type wrench to remove the filer cap. Turn off the rear filter shutoff valve before you check this one.
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
2010 Case 660 Trencher (A50322)
2010 Case 660...
