JD 1050
/ JD 1050 #1
jgbanshee
PA
JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
My 1050 wants to pop out of reverse unless I keep my hand on the shifter. I took the cover off and found that that reverse shift rail does not want to slide all the way into position like the other rails. The fork appears not to be bent, the detent ball bearings are new as well as the springs. Any insight?
/ JD 1050 #2
On my Tacoma pickup, a little teflon bushing just below the shifter ball area broke and caused it to not stay in 5th gear. Could your 1050 have some sort of gizmo like this?
Ralph
/ JD 1050
No, there is nothing like that in the 1050.
/ JD 1050
I found problem that kicks my tranny out of reverse. I long bolt used to hold the tractor clutch housing to the tranny housing was preventing the reverse idler gear to move into position. A shorter bolt solved that problem.
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
2009 JACK COUNTY KILL TRAILER (A67714)
2009 JACK COUNTY...
2013 Acura ILX Sedan (A66738)
2013 Acura ILX...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
porta potty (A68842)
20 FOOT SHIPPING CONTAINER WITH CONTENTS (A68842)
20 FOOT SHIPPING...
