JD 1050 Makeover
/ JD 1050 Makeover #1
ejb17
Western NY
JD 650, 4520
Just about done with a makeover on my 1050 MFWD. I made 1 good hood from 3 and found a set of fenders that were perfect. They were all blasted an painted and I bought a new front grill and headlight trim,which I thought were reasonable from the dealer. Replaced the dash,also reasonable, and repaired the warning light setup. Most of the seals in the front axle and pto I replaced and everything else was leak free. It has 2400 hours and I have 2 questions. What kind of life can I expect from the turbo and are parts still available? The turbo end play is still in spec but am interested in what you folks know. Trying to put pictures in. Thanks for the help.
/ JD 1050 Makeover #2
ejb, I found this old posting after you answered a question of mine. I have about 3200 hrs on mine, and have not yet had any turbo problems. Looks like you were doing some fine work in 2005.
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2012 JAYCO PINNACLE ALL-SEASONS 5TH WHEEL CAMPER (A64280)
2012 JAYCO...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
