JD 1026R
/ JD 1026R #1
x everything
Moose Jaw, Saskatchewan
JD 2305
Thinking of buying a 1026R with a QuikTrak Mower.
My question is would I be able to use a Front Mount Snow Blower on the 1026R?
Thanks
/ JD 1026R
Need a little more info, if you don't mind.
Is your 60" mmm the drive over Quik Trak?
I have read somewhere, don't have the manuals yet, that part of the front bumper has to removed to mount the frt blower, is this correct?
Can't seem to find a good pic of all this online.
Thanks
/ JD 1026R #5
Thanks
I have a 60" Drive Over, Auto Connect deck & a front blade for my 1026R. I will not be using a snow blower on it. The only difference between using the front blade & front blower is the addition of the front PTO & angle locking pin. After I installed the front hitch kit, all I have to do to install the front blade is remove the deck, install the bracket that is setting in front of the tractor & mount the hitch & blade.
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
150 GALLON FUEL TANKS WITH BRACKETS (A63569)
150 GALLON FUEL...
2005 PETERBILT 379 CAB ONLY (A63569)
2005 PETERBILT 379...
CASE TV380 SKID STEER (A64279)
CASE TV380 SKID...
2017 Case CX145D (A62177)
2017 Case CX145D...
Bobcat T66 Compact Track Loader (A64047)
Bobcat T66 Compact...
