JD 1026r wont start
   / JD 1026r wont start #1
rtunney
crossriver, ny
JD 1026r
have a new JD 1026r diesel, six mos old, and past 2 times using it when i tried to start it it wouldnt turn over, message on dash says put in neutral which i did and still had trouble. It started after a bit. Today it did the same after running for about 5 hrs cutting grass with the rear brush cutter. It wouldnt start no matter what, i left it for a bit and came back and it tries to start for a second then doesnt turn over and same message. The dealer is closed and i was wondering if anyone has any ideas. I guess its under warranty so the dealer will have to fix it?
   / JD 1026r wont start #2
Does the light stay on after you have the machine in neutral? It sounds like the switch that tells it when you are in neutral could be out of adjustment or malfunctioning.
I think thats exactly it, there must be some sort of kill switch that tells the starter im in neutral. I never had this with my JD 425, so dont know what i can do other than wait for the dealer. Any ideas are appreciated
   / JD 1026r wont start #4
It might not be that difficult to fix yourself if it is just out of adjustment. It probably has a jamb nut on either side of a bracket, loosen one and tighten the other to move the switch closer to the lever to make contact.
If you don't want to try and fix it yourself just wiggle the lever while in neutral and see if you can get it to start until you can get to the dealer.
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56438)
1992 Talbert 70...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
