JD 1025 MOWER DECK STAND
/ JD 1025 MOWER DECK STAND #1
JAMES KELLEY
MEADVILLE, PA
JD1025
I AM LOOKING FOR IDEAS ON HOW TO MAKE ONE END OF 1025-60" MOWER DECK STAND SWIVEL. CURRENTLY HAVE IT ON TWO STATIONARY AXLES/WHEELS AND IT IS A PAIN TO CHANGE DIRECTION SINCE I RECENTLY HAD BACK SURGERY. ANY IDEAS WOULD BE APPRECIATED!
/ JD 1025 MOWER DECK STAND #2
Don't follow.. maybe some pic or two will help.
Do you have the "drive-over" deck?
/ JD 1025 MOWER DECK STAND #3
I assume you have Larry's Mower Axles? You could try this product: Home
YES, IT IS A DRIVE OVER DECK JOHN DEERE 60 D. I HAVE AXLES AND WHEELS ON BOTH ENDS BUT WANT TO MAKE ONE END SWIVEL SO IT IS EASIER TO MOVE WHEN IT IS UPRIGHT.
/ JD 1025 MOWER DECK STAND #5
"easier to move when it is upright" is maybe not what I think it is.. you with a bad back, am not imagining you tilting that deck up (maybe to store? ).. or am I wrong? ok, just went to kennyd's link..so maybe what you have.
Again, some pics will help.
pls drop the CAPS, as your post will be easier to read (for me, anyway).. tks
note:
Looks like the deck dolly (link) could be modified with caster wheels and then just a little effort could go any direction. Good challenge for the deck dolly people.
/ JD 1025 MOWER DECK STAND #6
BT, he has (or has made something simular) to these: Mower Deck Axles,Carrera,Cayman,John Deere,Kubota
Here is my deck on them:
The problem with having one axles pivot could be the instability that could occur when turning.
James, can you weld and fabricate?
/ JD 1025 MOWER DECK STAND #7
Good idea there, and tks for the pic. See a few additional mods that could be made to the basic idea. Hope the OP sees the possibilities.
/ JD 1025 MOWER DECK STAND #9
What, maybe 20 # lift? Doubt much more with the length of those handles.
/ JD 1025 MOWER DECK STAND #10
Get a couple of these.
Either weld or bolt them onto a pipe that fits in the place of the current roller wheels.
Richard
Wholly cow, did you see the size of the horse lifting the dollie? I'm not sure i could lift my deck anymore using their dollie.
Deck Dolly Demonstration.mpg - YouTube
I decided to give the Deck Dolly a try with the longer handles. As often I have to clean the deck (seem like am always mowing when it is wet) I am looking for the fastest way to clean it!
I assembled and installed the deck dolly today. You were correct - you need to be a horse to lift and move the JD 60 deck. To remedy the situation, I installed /bolted on fiberglass handles from an old post hole digger which gave a 2' extension on the 6' handles. Now I can easily raise and move the deck!
/ JD 1025 MOWER DECK STAND #13
Pictures James, would be great.. ;)
/ JD 1025 MOWER DECK STAND #14
Thanks for reporting back James, I'd like to see a pic also.
/ JD 1025 MOWER DECK STAND #16
Looks good, I think even this weak-kneed guy could lift it now.
/ JD 1025 MOWER DECK STAND #17
Do they make one of those dollies for a 54" deck off my x738?
I would log into: deckdolly.com -( they probably do but just to be sure). if you order I would get with the long handles and the extra wheels for more stability and ease in raising deck to upright position.
2017 Bobcat MT85 (A64126)
2017 Bobcat MT85...
2011 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2011 FOREST RIVER...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
72" JCT TILLER (A62613)
72" JCT TILLER...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
