JCB transmission problems
   / JCB transmission problems #11
That's an uncalled for, unhelpful and probably inaccurate comment.
Maybe a particular issue unique to this machine.
You're absolutely correct.
There is a reason why JCB have the world's best-selling backhoe loader and it's definitely not because they're junk.
   / JCB transmission problems #12
Agree. JCB practically invented the backhoe. They are one of the worlds most respected manufacturers of heavy equipment. Pretty highly regarded backhoes.
   / JCB transmission problems #13
Are you able to determine if your actual problem is valves sticking or an electonic failure(bad sensor or circut board failing). I once had a circut board fail on a JD and perfectly mimiced fuel pump failure.
Good luck
   / JCB transmission problems #14
I remember talking to a heavy equipment tech about backhoes and he told me JCB backhoes develop a problem similar to what’s been described. He said the fix was pretty simple and inexpensive. I thought he said it was a solenoid in the dash, but this conversation took place a few years ago. Cant remember the fix!
   / JCB transmission problems #15
Has anyone figured out the problem? I have a 96 JCB 214E shuttle shift 4X4 backhoe that also wants to go into reverse after it warms up and then not move at all a few minutes later. Even with the newly replaced solenoid valve wires disconnected.
   / JCB transmission problems #16
I have had problems with my ignition switch would that affect the solenoids on top of the transmission
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
197711 (A51244)
197711 (A51244)
Tires (A50322)
Tires (A50322)
2009 CAT 140M MOTOR GRADER (A55745)
2009 CAT 140M...
2009 NISSAN Murano AWD SUV (A53424)
2009 NISSAN Murano...
2017 Nissan Versa SV Sedan (A53424)
2017 Nissan Versa...
