JCB locked up chain box full of hydrolic fluid
   / JCB locked up chain box full of hydrolic fluid #1
Donald Stokes
Lake Panasoffkee Fl
2002 jcb 1110 skid steer
I was doin work on my skid steer and the machine came to a screeching halt and stalled. I started it back up and proceeded and all was good. The following day while working it again it come a grinding screeching stop. It will not move maybe 6 inches backwards or forwards! If there is anyone that could help with a solution, I would appreciate it!
I also noticed that the chain box on one side has a substantial amount of hydraulic fluid and the other side has oil!
   / JCB locked up chain box full of hydrolic fluid #3
Well, is it hyd or mechanical.
If the chain box is too full then there is a leak in the hyd motor or planetary housing.
Can you jack up one side and see if that side is free wheeling?
I noticed that one side of the chain box has hydraulic fluid from machine the other side has oil. It will not move forwards or backwards without the scree aching grinding noise. When it happened once before it was when I bounced it, but ran smooth afterwards and made no noise at all!
I did try to move one control side and nothing
Zero Turn Mower (A55853)
Zero Turn Mower...
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A55852)
2012 Ford F-450...
2021 CATERPILLAR 226D3 SKID STEER (A52707)
2021 CATERPILLAR...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2007 Ford F-350 Stakebody Flatbed Truck (A51692)
2007 Ford F-350...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
