JCB locked up chain box full of hydrolic fluid
   / JCB locked up chain box full of hydrolic fluid #1
Donald Stokes
Lake Panasoffkee Fl
2002 jcb 1110 skid steer
I was doin work on my skid steer and the machine came to a screeching halt and stalled. I started it back up and proceeded and all was good. The following day while working it again it come a grinding screeching stop. It will not move maybe 6 inches backwards or forwards! If there is anyone that could help with a solution, I would appreciate it!
I also noticed that the chain box on one side has a substantial amount of hydraulic fluid and the other side has oil!
   / JCB locked up chain box full of hydrolic fluid #3
Well, is it hyd or mechanical.
If the chain box is too full then there is a leak in the hyd motor or planetary housing.
Can you jack up one side and see if that side is free wheeling?
I noticed that one side of the chain box has hydraulic fluid from machine the other side has oil. It will not move forwards or backwards without the scree aching grinding noise. When it happened once before it was when I bounced it, but ran smooth afterwards and made no noise at all!
I did try to move one control side and nothing
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
Deere 331G (A53317)
Deere 331G (A53317)
2015 Ford F550 Altec Bucket Truck (A52377)
2015 Ford F550...
CATERPILLAR 259D SKID STEER (A52707)
CATERPILLAR 259D...
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
