JCB 1400B Clutch Issue
/ JCB 1400B Clutch Issue #1
JCBGOZ
Forest City, Pa
JCB 1400B
I have an JCB 1400B Extendahoe with a Perkins 4.236 engine and a shuttle reverser trans. Machine # 317927/7. Two questions. First the machine buzzes momentarily when put into reverse, fluid changed filter cleaned no apparent problems or slipping, any ideas about the buzz, its done it for a while. Second just lately the clutch stopped working, you push it in and it does not disengage the trans the machine will continue in forward or reverse and you cannot shift the while moving any more, the rod is moving in and out of the trans, so the linkage is working. I have a shop manual for the machine but I do not have a set of gauges to check the pressures for the first issue and for the second issue the book has nothing about it. If anybody has a diagnosis, I can fix just about about anything but a broken heart, any help would be appreciated since money is tight. Thanks in advance for any help.
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
20ft 2-Door Shipping Container (A61572)
20ft 2-Door...
2006 Lexus ES 330 Sedan (A61574)
2006 Lexus ES 330...
2007 Peterbilt 378 (A62679)
2007 Peterbilt 378...
Enclosed Trailer with Lube System (A62613)
Enclosed Trailer...
