JB Weld
   / JB Weld
Email from Moen this morning saying the "handle adapter" hes been ordered and will arrive here before 1/5
No charge.:thumbsup:
I took the cue from bcp and used the vice grip method to get us through Christmas.
   / JB Weld #42
Glad to hear they are standing behind it and it is on its way. Always good to have a spare!
   / JB Weld #43
I have temporarily glued many things with JB Weld and , 10-25 years later it's still holding. I just clean and make surface perfect, mix some of "A" and some of "B" and clamp till cured. Beats me and I don't think I've ever had anything come apart.
I have many things "temporarily glued" together and it's amazing how many decades "temporary" can be.
:thumbsup::thumbsup: Looks like a good field expedient TEMPORARY repair.
   / JB Weld
It gets the job done but a small needle nose type vice grip would work better. Gotta pick up a cheep one tomorrow.
   / JB Weld #45
My guess is that Moen was aware of the problem and further guessing that your replacement will work just fine but will be different. Looked to be one of those "Achilles's heel" type things. They are in fierce competition with Delta (and Kohler but Kohler gets the huge brand name premium) so they want to please. As an aside, years ago I had a Moen failure that really amounted to nothing...the main part arrived one day, the O-rings the next day, and a tiny little pack of grease the next day. For their cost of the latter 2 deliveries (like a dime) they would have saved about $10 in shipping fees had they just included them in the package with the main part. I shake my head a lot at how some companies do business.
   / JB Weld #46
I have had great results gluing things over the years, especially with JB weld. Why I think that happens is because I carefully clean the mating surfaces and do a sample mock up using clamps. Then I apply the glue/epoxy, clamp securely and allow a little squeeze out of glue that helps strengthen the joint. Not sure about this case but I believe most failures are poor alignment, no clamps and insufficient cure time.
   / JB Weld #47
I really don't remember when JB weld came on the market but back in the early 70's I worked at a generator, starter repair shop. We use to use something that looked almost like JB but I think the ratio was 1/2 to one. You mixed it just like JB and then would spread in over the diodes and where the wires connected on heavy duty truck alternators to keep the vibrations from the wires to brake off the lead in the diodes. I had bought a Case tractor from some one for around $150, (nice tractor) it was a basket case. Engine tore apart, a main bearing had spun in it taking out the crank and wiped the saddle and cap. I finally found a place that built the crank back up but could not find a machine shop that could build the block and saddle back up and line bore it. I installed all the other main bearings, cleaned the bad main cap and block up real good, mixed up some of that epoxy, spread it all over the cap, and block, laid the bearing in it, and then the crank, bolted it down just hand tight, let it set for a day with a heat light on it, then torqued it per specs. I used the tractor for several years and finally sold it and made a nice profit and as far as I know the owner is still using it. I think the epoxy was made by Delco Remy. It came in a tube about 5 times larger than JB. I bought a couple of tubes but over the years used it up. I also had a Cat engine that the cam had spun a bearing, polished the cam up, got a new bearing and cleaned the bore up real good and installed the bearing then put the cam in right away,, let it set for a couple of days and start it up. Still running. Red Neck repair shop.
   / JB Weld #48
Different warehouses maybe?
   / JB Weld #49
Even if that was the case, somebody should be paying attention. That little pack of grease was not much bigger than a thumbnail. Where ever the cartridges ship from should have a supply of the grease packs and the O-rings for that matter (or just include them all in the cartridge packaging...can't possibly cost Moen much compared to the cost of shipping.
Allied 760 Loader (A50515)
Allied 760 Loader...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2019 FREIGHTLINER SPRINTER 2500 (A51219)
2019 FREIGHTLINER...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
