JB Weld
   / JB Weld #1
Toyboy
Platinum Member
Hayward Wi
Kubota BX2230D
Hi guys and Merry Christmas.
I have a question on JB Weld. I've never used it before, and according to the directions it says mix equal amounts together. What happens if your heavy on one or the other? Won't harden? Poor bond?
   / JB Weld #2
One is the resin and one the hardened. So if not enough hardener it will not set as hard, too much hardener it harden , but will lack strength.
   / JB Weld #3
I've been using JB weld for some years now.
The bigger question is why wouldn't you mix equal amounts together? Never not mixed it together rather equally to give you an answer, but Clint's answer seems reasonable;)
Lot better than West Virginia Chrome (AKA duct tape LOL).
   / JB Weld #4
Equal amounts give good work time and proper hardening. Lack of proper hardener will cause slow curing time and possibly not cure at all if not enough hardener.
I mix it by applying a dollop of the black resin and along side a dollop of the white hardener trying to get approximately the same size dollop from each tube. Then thoroughly mix to a uniform color and apply. It does creep quite a lot before hardening, so best to have the part that you are gluing level, then watch for excessive creep. It wont hurt to screed it back in place if it is still liquid but don't move it if it is already starting to cure.
I use JB Weld on lots of things but it has it limits as to what it will stick too. Some types of thermo-plastic wont bond well with it.
My favorite mixing pot is a small plastic container that my scotch brand black vinyl tape came it. The hardened resin can be popped loose easily (note that it is one of the types of plastic than doesn't bond well). Softer plastics like PVC can sometimes bond well. I fixed my tractors fuel tank 7 or more years ago and it is still holding.
   / JB Weld #5
When JB welding, I put a lighter lens in my helmet. That makes it easier to see equal amounts, compared to doing it by touch. :laughing:
Bruce
   / JB Weld #6
Surface preparation will help the adhesion capabilities of just about any epoxy etc., etc...
Even microscopic scratches help a good bit on smoother surfaces...
   / JB Weld #8
Nobody mentioned that getting equal parts is an EXACT science requiring precision scales and stuff!:) Like epoxy, the eyeball test is good enough.
   / JB Weld #9
Bruce
Thanks for the tip, Bruce. I will have to try that.
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2011 CATERPILLAR 259B3 SKID STEER (A51242)
2011 CATERPILLAR...
2018 Ford F-550 Truck Altec AT40G Insulated Bucket Truck (A50323)
2018 Ford F-550...
2017 VOLVO ECR88D EXCAVATOR (A51242)
2017 VOLVO ECR88D...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
SANY SY75C EXCAVATOR (A51242)
SANY SY75C...
