J2030H Keeps dying - Safety controller issue? Experts step in!
   / J2030H Keeps dying - Safety controller issue? Experts step in! #1
Alex0413
Kubota L2350 & L245
Hi, I have a 2013 J2030H with 348hrs, that has been trouble free until recently. I went to use it and it didn't have power.. long story short turned out to be a bad connection on the positive terminal . Starts up and idles perfectly : when I remove the parking brake or hit forward/reverse on the HST is dies! okay must be the seat switch right?! NOPE: bypassed the seat switch and tested the wires: fully voltage going through the wires, problem still persists!
Now I don't have a J2030H Service manual, because you can't find them, but I have the Boomer 25 manual. I thoroughly study all diagrams and circuits, then systematically test every safety switch: all functioning correctly. Test PTO switch: checks out perfect. All fuses correct. No matter what, when I remove the brake or hit the HST pedal it dies! So I need to test the safety controller to to confirm that it's getting voltage from the seat switch... but I can't find it! Dash it out, tracing wires, taking this tractor apart and I can't find the damn thing for the past few days!!!! Looking at the Boomer 25 manual, it's behind the console cover to the right, but nothing is there on mine.. I'm to the point where I'm about to run and ON/OFF switch to my fuel solenoid to bypass all this crap. Anyone got any ideas of what I'm over looking here?? Anyone have a J2030H service manual so we can compare wiring diagrams?
Well called the local LS dealer today and told them my issues, and that I'm using a Boomer 25 manual.. they said that there is no "safety controller" present on the J2030H and were kind enough to email me PDF of the LS factory service manuals so I could look at the wiring diagrams: J2030h is similar but uses a Safety Relay instead of a Safety controller, which is the big relay with 8 wires behind the console cover.
Looking at my issues (not seeing the seat safety switch having operator present even with switch bypassed), I determined that the safety timer that terminal 33 from the seat switch goes to on the dash into 33 - has a malfunction. So I can combine terminal 33 (green/blue wire) with 27 (green/yellow wire) coming from the safety timer in instrument panel , and this will send the needed 12v to the safety relay ALWAYS showing operator present. The safety start system will still be in place!
Below is the factory LS J2030H wiring diagram illustrating my above solution:
   / J2030H Keeps dying - Safety controller issue? Experts step in! #3
On my zero turn mower a few years back, one of the wires for the safety switch simply broke. Was able to locate the break visually (luckily) and just splice it.
I mention this just in case that is what is causing your issue - check all the wiring first.
   / J2030H Keeps dying - Safety controller issue? Experts step in! #4
Glad that you were able to get it fixed without too much trouble!
   / J2030H Keeps dying - Safety controller issue? Experts step in! #5
I too have the same problem. I also have check/tested each individual safety: Neutral, Brake, PTO, seat switches. My J2030H starts great. The seat switch is removed with the wires directly connected.
Searching around I found 3 wires under the dash had been chewed by mice. I repaired the wires. Yet still have the same problem. Not only when the neutral switch is moved but also immediately when the PTO is engaged.
I have jumped the GY to the GL (green and blue). The same problem still exists.
I’m going out now to again to connect the 27 and 33 wires together.
Well, upon closer inspection it seems that my wire colors are not the same as the schematic the seat switch is Green not Green blue. Though there is Green blue. The schematic does show a Green wire.
   / J2030H Keeps dying - Safety controller issue? Experts step in! #6
Does not show an all green wire which is my seat switch wire. Once made it energizes the RY wire.
Anyway, I’m heading out to jump each safety switch individually.
2002 Western Star 4900 T/A Galbreath Rolloff Truck (A55852)
2002 Western Star...
2025 AGT SSCM615 (A56469)
2025 AGT SSCM615...
21' Roll Off Container (A56469)
21' Roll Off...
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
USA Attachments 34' Excavator Bucket (A56469)
USA Attachments...
