J.J. Rear Remote Hyd. Return Line ??
   / J.J. Rear Remote Hyd. Return Line ??
Here's a quick edit which shows the factory loader valve, and then the setup with the new remote valve added. A two spool valve is not much more than a single, so I'd get a 2-spool valve and plug the ports until you need it. (Or if you don't mind, plumb it now!)
Factory loader valve:
New setup, your new lines are in color:
Note the green line tees to the existing black line, you can do this with simple pipe fittings. Or as I mentioned you can bring it to one of the two red-capped fill ports on the transmission/rear housing, however the rear one has a vent you'll need to replicate if you go that route.
Hope this helps.
ishiboo in your second drawing are your drain lines run to the port on the lower front of the hyd. block closest to the tractor oil pan ?
Look at your parts manual and look for the aux. remote valves near the end of the list. Check with your dealer and see if he can order 99063-93300, if so that well give you a way to hook a set of remotes. It goes right under your seat and you well save a lot of $$$$ in hose.
Checked with the dealer today , 99063-93300 is available at a cost of $184.00 / food for thought , thanks for the pointer Leejohn .
231855d1317503976-hydraulic-winch-installation-kubota-l2950-hydraulic_block_diagram.jpg
   / J.J. Rear Remote Hyd. Return Line ?? #34
My god! That's just a block with a few holes in it, 2 are tapped and that's about it.
I hear you .......going to look at trying to build one myself . Do you have any dimensions / info that i can use for a guideline Leejohn ?
   / J.J. Rear Remote Hyd. Return Line ?? #36
No I don't and it doesn't show a plate to cover the holes. If it does have one you could use it as a template.
2004 CAT 953C Crawler Loader (A47477)
2004 CAT 953C...
1999 Volvo VN Truck, VIN # 4VG7BBRFXXN772814 (A54865)
1999 Volvo VN...
New JMR Skidloader Stump Bucket (A50775)
New JMR Skidloader...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
