j d model d170 leaving strips when i mow
   / j d model d170 leaving strips when i mow #1
ed miller
jackson tn
j d mod.170
Have others have problems of blades leaving two strips aprox 1 inch in the middle of the cut. I have tried changing the blades ect. mower has only 12 hrs on it, any ideas?
   / j d model d170 leaving strips when i mow #2
There is a possibility that the wrong blades were installed. I would take them off and check the numbers.
Greg
   / j d model d170 leaving strips when i mow #3
Have you mowed any really damp or wet grass? Those decks love to cake up with grass underneath. It doesn't take much to leave a stripe.
As the guy above said, make sure you have the right length blades and they are installed right side up.
   / j d model d170 leaving strips when i mow #4
Level the blades. But check the tire pressure first. That solved this problem for me. There should be instructions in your owners manual for blade leveling.
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
UNUSED Safety Work Gloves (A53117)
UNUSED Safety Work...
200722 (A51247)
200722 (A51247)
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2015 KENWORTH T680 SLEEPER (A54607)
2015 KENWORTH T680...
Honda EU3000is Gasoline Companion Inverter Generators (A55851)
Honda EU3000is...
