j d model d170 leaving strips when i mow
   / j d model d170 leaving strips when i mow #1
ed miller
jackson tn
j d mod.170
Have others have problems of blades leaving two strips aprox 1 inch in the middle of the cut. I have tried changing the blades ect. mower has only 12 hrs on it, any ideas?
   / j d model d170 leaving strips when i mow #2
There is a possibility that the wrong blades were installed. I would take them off and check the numbers.
Greg
   / j d model d170 leaving strips when i mow #3
Have you mowed any really damp or wet grass? Those decks love to cake up with grass underneath. It doesn't take much to leave a stripe.
As the guy above said, make sure you have the right length blades and they are installed right side up.
   / j d model d170 leaving strips when i mow #4
Level the blades. But check the tire pressure first. That solved this problem for me. There should be instructions in your owners manual for blade leveling.
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
MDB F23-80 (A51406)
MDB F23-80 (A51406)
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A54757)
UNUSED WOLVERINE...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2015 Ford F550 Service Truck (A52377)
2015 Ford F550...
