J.D. 850 Throttle Control
/ J.D. 850 Throttle Control #1
DennisY
Maine
JD 850
The throttle on my 850 will not stay in the open position unless I keep my hand on it or keep it open via the foot control. Anything specific I should look for when I take it apart? /forums/images/graemlins/confused.gif
/ J.D. 850 Throttle Control #2
Dennis,
The first thing I would try is tightening up the friction disc.
Where the throttle lever bolts( pivots) on the tractor there is a nut with a washer (friction disc) behind it.
Slightly tighten the nut and your throttle lever should stay put.
If it still moves while in use the friction disc may be worn.
An easy repair and only takes a few minutes.
Good luck
Vince:
Thanks for the response. There dosen't seem to be a friction nut. All the linkage seems to be put together with cotter pins.
I was going to attach a photo but apparently the systme will not take that large a file.
Sorry.
/ J.D. 850 Throttle Control #4
I wiil try to post a page from my 850 service manual on the throttle linkage.
#8 is the friction disc, you need to tighten the nut on the backside of the linkage to put more tension on the friction disc.
Sorry, Its been a few years since I adjusted my 850 throttle linkage and could not remember for sure how I did it.
Vince:
That should help a lot. Thank you.
Dennis
Vince:
Thanks again for the page from your manual. It looks like my problem is that part #3 the ball is missing. I did take out the pin and coil spring and found nothing in there. Looks like a trip to the J.D. Dealer. I really appreciate your help.
PAIR OF 10' RAMPS W/10' EXTENSIONS (A62131)
PAIR OF 10' RAMPS...
48x4 Mini Skid Trencher (A63118)
48x4 Mini Skid...
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
2018 HINO SA (A58214)
2013 FREIGHTLINER M2 112 S/A 4X2 DAY CAB TRUCK TRACTOR (A59910)
2013 FREIGHTLINER...
HOMEMADE 52"X12' S/A TRAILER (A62130)
HOMEMADE 52"X12'...
