I've got double vision!
/ I've got double vision! #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
Got my new (used with 290 hrs) Massey 1652 in the mail last week. Put on about 25 hrs so far... So I'm putting the 1648 up for sale if anyone's interested.
Why I bought it?
-LOVE my 1648. As I acquire more equipment and machinery for my business, this "large frame CUT" will remain my "main-use" machine for now. The 1652 uses a 3.0L diesel (largest engine in the CUT class, from any mfg) compared to a 2.2L in my 1648. There's about 30% more available torque in the 1652... So i figured since I'm keeping this sized tractor for a long time, might as well step up to the larger engine. Found a great deal finally on a 1652, so I went for it.
Haven't used the PTO yet so not sure how much I'll notice the additional power there... But it does seem to pull my boxblade a bit better. It also has more hydraulic flow: 12.3 GPM vs 11.6 for the loader/implement hydraulics, and 5.2 vs 4.9 for the steering pump.
It also has loaded rear tires, wow what a difference! I'm able to stay in 2wd more than before, even with the wheel weights.
Updates as I get them.
/ I've got double vision! #2
Congrats! All four tires loaded allows one to wreck stuff. Smile.
/ I've got double vision! #4
Congrats on the new machine. Even though it may seem to be an incremental upgrade, I know there have been many times when just a "little" more power and/or traction would have been nice. Your existing Massey has served you well, so this one should be even better.
/ I've got double vision! #5
Can't pass up good deals no way man. So, how many does this make you have bought and sold in the last what 2-3 years? LOL B.
Lol ... This would be my 5th in 4 years.
/ I've got double vision! #8
Nice pair of tractors for sure.
So how long before you get a 1660? Have to hurry if you want to find a like new one.
No, won't get the 1660. Need HST, and in the 16xx series, HST stopped with the 1652. Same engine as the 1655/1660 tho, so I may bump up the fuel pump to get the 59 HP that the 1660 has, we'll see. Next tractor will probably either be a CTL, or a larger "industrial" tractor with gear/shuttle shift. This 1652 should serve me for a long time as my "go to" machine.
/ I've got double vision! #10
Sweet, time for a profile update:thumbsup:
/ I've got double vision! #11
I looked at tractordata quickly to compare the models but did not check the transmissions out. I have always liked MF but don't have a dealer any where close to me.
When I was shopping for my tractor I did get a chance to compare a box blade with both a 4520 and a 4320, big difference in pulling speed with a loaded box. I would have tried a 4720 but the dealer did not have one in stock.
I like the 4520/4720... It may have been you, or another member (can't remember) who helped point out the 400cx loader specs compared to the 400x... And that definitely helps make the the JD 4520/4720 look appealing to me. I just can't get over the cab though... It's just too small for me.... And a couple other minor things that I prefer on the MF. But nice machines.
I've got some stumps to grind soon ... That should help shed light on whether or not I notice the added power.
/ I've got double vision! #13
I thought the 1660 was available in either an HST or the dyna six speed push button transmission, no?
No, it has 3 options. Gear, Gear-Shuttle, or Dyna-QPS 12x12.. No HST tho :-(
The new series, you can get the 1758 HST
/ I've got double vision! #16
I guess you are happy with massey
/ I've got double vision! #18
How is the 1652 doing?
Old thread here... But GP, this Massey is holding up just as well as the other one did, flawless so far. I think I'm up somewhere around 700 hrs now, but not completely sure.
2022 MACDON FD140 FLEX DRAPER (A63291)
2022 MACDON FD140...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2012 Mercedes-Benz 2500 Sprinter Van (A61573)
2012 Mercedes-Benz...
500 Gallon Hydraulic Oil Holding Tank (A61573)
500 Gallon...
CASE INTERNATIONAL 3900 DISC HARROW (A63291)
CASE INTERNATIONAL...
Geringhoff Control and Manuals (A63117)
Geringhoff Control...
