Snow It's Snow Time???
   / It's Snow Time??? #1
SuburbanSam
DC Suburbs (1601 Pennsylvania Ave)
Cub Cadet SLT1554
I've seen many dealer sites that have a model 190-032 snow thrower and a model 190-823 snow thrower both specifically for the 1000 and 1500 series tractors. THere is also a 190-341 model for the 2000 series.
I have a SLT1554
1) Are the front ends of the 1500 and the 2000 series tractors similar enough for me to try and buy the 190-341 model? There are many good posts out here recommending the shaft driven thrower (shaft driven inside the thrower and attaches to the PTO belt on the tractor)?
2) Does anyone know the differences in the two models specifically built for the 1000/1500 series? Again many posts advising "get the newer one", but I don't knowing which one that is???
My dealer tells me that I shouldn't buy any one of them and that I should buy a $1599 Toro walk behind...
   / It's Snow Time??? #2
Why does your dealer say that, Mine is from MTD. It is a unversal 42 inch snow thrower and it works fantastic. You will need tire chains. Mine walks through a foot of snow with no problem
Cub Cadet 1000 Series Tractors
I also use the snow cab with mine. I love it
   / It's Snow Time??? #3
Actually I agree with your dealer,,I had a snow blower assy for my 1450 cub.It did a great job but --it took a lot of time changing over from mower to blower, Remove mower deck,put chains on,put weights on,hang blower assy.then it took up almost as much room as a small car in the garage.I found a used Ariens snow blower for 500 bucks many years ago, it takes up almost no room, manuvers much better does as good or better a job as the cub. and I'm not putting the wear and tear on the cub during the winter. So I sold the blower unit from the cub. (And I get an adverage 120-160 inches of snow here)
   / It's Snow Time??? #4
I would rather run my tractor year round than let it sit all winter. Once it is set up it is easy. I have a 700 foot drive and can do it in 3 passes in about 1/2 hour. My shop only has tractors and tools in them anyway, I would never waste a garage on a car. I would much rather sit in my snow cab and drive the blower than stand behind it with 1/2 the cut
   / It's Snow Time??? #5
700 ft driveway?
You need a road grader :)
-Larry
   / It's Snow Time???
Want to say THANKS for the responses. I'm going with the 190-032. And much like Timber I'd like to keep my tractor in use all-year-round.
For deck removal I'd thought that I could jack the mower up and set it on stands in order to remove the deck easier. Anyone have any personal preferences or tips for how to effectively remove the deck.
   / It's Snow Time??? #7
You should be able to just disconnect the deck and slide it out, sometimes need to turn the steering wheel a bit to clear the deck wheels. Jacking the front end a few inches for clearance might be needed, not sure on the 1554.
The main drawback to tractor mount blowers is maneuveribility. For a large or long driveway they are great, for a smaller drive the walk behind is easier to turn. Then again its just fun to run the tractor in the winter, I used to plow with mine and though not very effective in heavy snow it was a lot of fun.
   / It's Snow Time??? #8
SuburbanSam
Just looked at your location. You mean with all that hot air in that location you need to remove snow ?? I would think it would melt from just from being downwind from the wind bags !!
Let the guys know how it works as there has been numerous questions about the comparisons. I prefer a plow, but then I have open space in which to push it. I actually use both in heavy snows.
charlie in VT
   / It's Snow Time??? #10
Timber said:
I just converted her over yesterday
Timber,
Where did you get the cab? I have a 2542 and I've been looking for a cab.
SAKAI SV510 SMOOTH DRUM ROLLER (A51242)
SAKAI SV510 SMOOTH...
2020 POLARIS SPORTSMAN 450 4 WHEELER (A51243)
2020 POLARIS...
Barn Wood Planter Box (A50515)
Barn Wood Planter...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
VERMEER S925TX STAND ON SKID STEER (A51242)
VERMEER S925TX...
2015 Ford F450 Service Body (A47384)
2015 Ford F450...
