It's official!! but it won't move?!?!
   / It's official!! but it won't move?!?! #1
TNTractor1
Jackson, TN
2011 JD2520
My brand spanking new 2520 was delivered last night! She has .5 hours on her. I do have a VERY newbie question. I have searched the manual and google and still can't find the answer. Ok this is a little embarrassing, but... How do I make it go forward or reverse? I cranked it, made sure the parking brake was off, put it in Low and pressed the reverse pedal and nothing... same with forward. I am not sure I have it in gear... Seems like the gear lever only travels an inch or less when going from N to L or H... is this right? Is there a clutch to engage before selecting L or H? Since I had it shipped from out of state I got zero hand-on training (that's the downside of buying out of state). For the life of me, I can't figure out what I am doing wrong. It's torture seeing her sitting there, but not being able to do anything! :confused:
   / It's official!! but it won't move?!?! #2
Is the parking brake on?
   / It's official!! but it won't move?!?! #4
Man I feel for you ... gotta be a simple solution ... can't wait for the answer.
   / It's official!! but it won't move?!?! #5
When you press the pedal, does the hydro whine loudly,? if so then it is in gear and the brakes are locked somehow, if it does not complain loudly, then the range selector is not in gear. I am not familiar with you model, but if it has a clutch push it in, and move that range selector smartly back and forth and end up in Low, I am thinking you are afraid to break it, and and are not being forceful enough,. When they are new, range selectors can be balky. you also might try if you have a bucket. trying to set the bucket edge down on the ground with a little pressure then "curl" a little which should make the tractor move just a tad backwards. "curl" or "dump" to jiggle the tractor a little foward and backwards. and trying the range selector while doing this. put some modest power behind the range selector lever and move the darn thing!
I bet this is the problem.. give it a try.
James K0UA
I will double check the parking brake again tomorrow... I have a JD LX172 riding mower I have had for years and the parking brake looks the same... big orange thing you pull out ... maybe the 2520 works different though even though it looks the same.
   / It's official!! but it won't move?!?! #7
wow-that sucks... Poor guy cant play with his new toy.. That would drive me crazy..Let us know whats wrong its got to be something simple??
AndyG
   / It's official!! but it won't move?!?! #8
Well if it is the brakes, try stomping the service brakes hard with you foot, and see if the lever pops back up.. still again I dont know your model, but in general terms if you push on the hydro with the parking brake set, it will complain loudly, It may not move, but it is gonna let you know to get OFF! of that pedal with a loud whiney scream. But again if it does not do this then most likely the range selector not in gear. Possible linkage problem, or something else.
James K0UA
   / It's official!! but it won't move?!?! #9
I hope this not another bogus post? I find myself sitting here waiting to find out is going on!!!!!!:confused2:
AndyG
   / It's official!! but it won't move?!?! #10
Well we need jinman or someone on here who actually owns a NH, Us Kubota guys are trying, but it would be good for a NH guy to comment
UNUSED LANDHONOR PR-12-72W 72" HARLEY POWER RAKE (A54757)
UNUSED LANDHONOR...
NEW HOLLAND 3930 TURBO TRACTOR (A54756)
NEW HOLLAND 3930...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
Brock 5 Ton Feed/Grain Tank (A55218)
Brock 5 Ton...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
