It was working just fine...
/ It was working just fine... #21
Brown, you just had to throw that wet blanket didn't ya?
Beat me to it.
I've got a perfectly good spare battery myself as a result of very similar process.
The thing that jumps out at me is how perfect all the connections have to be. Even my Deere Dozer is not as picky, and I'm running a single battery on that bad boy too.
Interesting.
Joel
/ It was working just fine... #22
Joel
I will bet the ground on the Deere goes directly to the engine block and not to the frame.
/ It was working just fine... #23
Wallace was correct................:p
/ It was working just fine... #24
The deere ground is on the frame at the battery box. Much bigger cable, but not to engine block.
I've never had a machine of any kind as finiky with regards to battery connections as my Kioti.
Including two Kubota tractors (used to leave terminals loose so I could easily remove and replace batteries) and my Deere Dozer.
OK, so maybe I did not need the new battery. What I got me is a $70 lesson in basic electrical grounding techniques and the finer points thereof. Continuing Education Points with certificate will be in the mail soon, I am sure.:D
Good practice for when I install a solar PV system.
/ It was working just fine... #26
Joel
He is the most reliable source of inane comments on TBN bar none. :(
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A65563)
2007 International...
