It took me several days to figure this out
   / It took me several days to figure this out #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
The timer knob on the clothes drier broke and we had to resort to locking pliers to turn the D stem. I started a search locate the model of the dryer so I could order another knob. Luckily, I found the word SIGNAL at the top left hand corner of the drier and was all set to order a timer knob for a GE SIGNAL drier when I realized, this knob turns on the "signal" that the load is dry. I finally got the model number and located a cheap replacement on-line but shipping and handling was much more than the cost of the knob. Being stingy, I tried to locate a knob on an old appliance. With everything going digital these days, success eluded me. Then, I remembered the signal knob right on the drier. We never use it and it fit the stem on the timer.
l probably shouldn't tell about the fridge that makes heavy and light ice. :confused:
   / It took me several days to figure this out #2
I had a TV knob on my trash compactor and the light ice is for those extra dark nights.
   / It took me several days to figure this out #3
We just bought a new washer/dryer set. They only have one knob each, to set the type of load you have. The rest is buttons, cute little digital ditties and das blinkenlights.
   / It took me several days to figure this out #6
Ours don't have knobs! all push button. Goes out ,likely a whole PC board to replace.
   / It took me several days to figure this out #7
Which is exactly why I purposely purchase analog appliances. If one function of the digital printed circuit board (PCB) goes wrong then the entire board needs to be replaced (in this throw-away society we live in) and that costs a lot of money and usually needs to be installed by a manufacturer certified 'professional' for warranty purposes.
An analog switch is a matter of swapping it out yourself as the wires are on stake-on posts. Just make a drawing (wiring diagram) of where the coloured wires go to on the old switch, then follow it when hooking up the new.
   / It took me several days to figure this out #8
I got so tired of fixing my old knob and dial washers that I went out and bought two all digital ones. I have never had an issue with the digital ones, ever. It has been about 6 years and I was fixing the old ones every year it seemed. I think I had Sears worst washers they ever made. I now have LGs.
   / It took me several days to figure this out #9
Tom, that is what we have also, running on 6 years right now for the set. Last summer I thought I had to replace the board in the washer, cost just under $100, then found out it was a blown fuse, I had to specialty order them, 10 pack at $11.:laughing:
   / It took me several days to figure this out #10
Probably shouldn't. The Nuclear Regulatory Agency and the Department of Homeland Security might decide you're a terrorist trying to make a hydrogen bomb out of heavy water.
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
183 (A52705)
183 (A52705)
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
