It took me several days to figure this out
   / It took me several days to figure this out #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
The timer knob on the clothes drier broke and we had to resort to locking pliers to turn the D stem. I started a search locate the model of the dryer so I could order another knob. Luckily, I found the word SIGNAL at the top left hand corner of the drier and was all set to order a timer knob for a GE SIGNAL drier when I realized, this knob turns on the "signal" that the load is dry. I finally got the model number and located a cheap replacement on-line but shipping and handling was much more than the cost of the knob. Being stingy, I tried to locate a knob on an old appliance. With everything going digital these days, success eluded me. Then, I remembered the signal knob right on the drier. We never use it and it fit the stem on the timer.
l probably shouldn't tell about the fridge that makes heavy and light ice. :confused:
   / It took me several days to figure this out #2
I had a TV knob on my trash compactor and the light ice is for those extra dark nights.
   / It took me several days to figure this out #3
We just bought a new washer/dryer set. They only have one knob each, to set the type of load you have. The rest is buttons, cute little digital ditties and das blinkenlights.
   / It took me several days to figure this out #6
Ours don't have knobs! all push button. Goes out ,likely a whole PC board to replace.
   / It took me several days to figure this out #7
Which is exactly why I purposely purchase analog appliances. If one function of the digital printed circuit board (PCB) goes wrong then the entire board needs to be replaced (in this throw-away society we live in) and that costs a lot of money and usually needs to be installed by a manufacturer certified 'professional' for warranty purposes.
An analog switch is a matter of swapping it out yourself as the wires are on stake-on posts. Just make a drawing (wiring diagram) of where the coloured wires go to on the old switch, then follow it when hooking up the new.
   / It took me several days to figure this out #8
I got so tired of fixing my old knob and dial washers that I went out and bought two all digital ones. I have never had an issue with the digital ones, ever. It has been about 6 years and I was fixing the old ones every year it seemed. I think I had Sears worst washers they ever made. I now have LGs.
   / It took me several days to figure this out #9
Tom, that is what we have also, running on 6 years right now for the set. Last summer I thought I had to replace the board in the washer, cost just under $100, then found out it was a blown fuse, I had to specialty order them, 10 pack at $11.:laughing:
   / It took me several days to figure this out #10
Probably shouldn't. The Nuclear Regulatory Agency and the Department of Homeland Security might decide you're a terrorist trying to make a hydrogen bomb out of heavy water.
TANK MANIFOLD (A55745)
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
