It fell in the tank……
   / It fell in the tank…… #11
"Is there anything in the tank that I could grab that would mess up the fuel gauge reading? "
There will be a fuel lever sender (probably a float on a rod) in there, but that's going to be fixed to the bottom of the tank and should run vertically to close to the top of the tank.
The tube you dropped will move easily. If you grab something in there that resists pulling by the grapple, you snagged the wrong thing.
If you need to operate your tractor, I'd just put a ½ gallon of fuel in at a time and not even worry about that tubing. Once you've done your chores, you can either just run the tank close to empty (so you can see the tube to retrieve it) or pull the fuel line off and drain the fuel. If you pinch the fuel line when you pull it off the tank, you'll keep fuel in the line. That will eliminate the need to bleed your injection system. If you tractor has an auto-bleed injection system, I wouldn't even worry too much about emptying the tank at all.
If the object you dropped was small (like a nut or something), you might be concerned. But a tube the size you described isn't like to block a fuel line. Now, depending on the plastic, the diesel fuel could dissolve it. That would be a real bummer as it could clog the fuel system. But I'm sure you used something that is fuel resistant.
One safety tip... Diesel fumes aren't near as explosive as gasoline vapors. However, this is still fuel that burns so use a modicum of common sense when you're retrieving that tube (i.e. don't use a match or cigaret lighter for illumination)
   / It fell in the tank…… #12
use the tractor till it is pretty close to out of fuel, then u should be able to see it and grab it with the tool described above.
   / It fell in the tank…… #13
Re: It fell in the tank……
Jim & Bird,
We got a real heavy frost this morning. So heavy I could plow it. Much fun was had! (see attachment).
Larry /forums/images/graemlins/cool.gif
   / It fell in the tank…… #14
I can't believe you all have missed the most obvious answer. Simply turn the tractor over and it'll probably fall out on its own. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Hey someone has to be a wise guy. /forums/images/graemlins/grin.gif
   / It fell in the tank…… #15
My B7500 has the gasket from the cap down in the tank somewhere. I tried that cable-grapple-finger thing with no success, unless you count catching the fuel sensor several times. It went in a year ago, and after spending an hour trying to get it out, decided the heck with it...............chim
Thanks guys, I’ll try the pickup tool first and the R.O.P.S. second, . . .that is if it hasn’t already dissolved. (Larry you really make Texas look good this time of year.)
TxDon
   / It fell in the tank…… #17
</font><font color="blue" class="small">( We got a real heavy frost this morning. )</font>
Wow! Larry, you sent a chill up my spine. /forums/images/graemlins/shocked.gif I'm so glad I live somewhere I don't have to deal with that stuff. Yesterday morning it was 24º, and this morning it's 49º. Before the day is over, it's supposed to top 70º. You have every bit of my sympathy and admiration for being able to cope with snowfall like that. /forums/images/graemlins/crazy.gif
   / It fell in the tank…… #18
Re: It fell in the tank&#8230;&#8230;
Looks like you were having fun, big boys and their toys. As for me I am getting frustrated waiting for the heavy snowfalls Michigan often gets in December....all that green (pun intended) spent on my new JD and it has been sitting indoors for the past 3 weeks. I WANT SOME SNOW.
   / It fell in the tank…… #19
Yep, Larry, that's a bit heavier frost than I've ever seen personally. /forums/images/graemlins/laugh.gif
   / It fell in the tank…… #20
Hi...
Same "tube in the tank" happened to me... /forums/images/graemlins/mad.gif
2 bent coathangers... an assistand held flashlight... pliers... and an hour's worth of aggravation got it out...
Dave...
2004 IC Corporation 3000IC School Bus (A55852)
2004 IC...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
42006 (A55851)
42006 (A55851)
1980 ATHEY AB6905 MOTOR GRADER (A52707)
1980 ATHEY AB6905...
1998 CATERPILLAR 953C CRAWLER LOADER (A52707)
1998 CATERPILLAR...
