Iskei tu2100
/ Iskei tu2100 #1
Iseki58
Iseki TU2100
Hi all
I’m having some troubles with my tractor hydraulics they were working ok then while doing some loader work they suddenly slowed right down and now they will barely lift up same with the 3 pt hitch won’t lift any weight
I checked the hydraulic filter an oil level all good then took the hose off coming out of hyd pump has good flow and pressure also checked hose going into the loaders hydraulic control it also has good pressure
Wondering if anyone can help?
it’s an Iseki tu2100 tractor 20hp
/ Iskei tu2100 #2
If you have good flow and pressure the system should work. What kind of flow and pressure did you have? Look for any pinched or kinked hoses. Replace the hydraulic filter. Do you have a screen somewhere on the suction or return side of your system?
/ Iskei tu2100
I’ve timed how long the hose takes to fill up a container it’s about 10LPM or 3GPM I’ve already cleaned the filter and all hoses look ok. It doesn’t have hyd remotes
It seems to have good pressure and flow but just quits when under a load could it be the bypass valve?
/ Iskei tu2100
Not sure about a screen on the return side it looks like the hose just goes straight from hyd pump back into top of trannny
/ Iskei tu2100 #6
I'd start simpler than taking the hydraulic lines apart. Hopefully you checked the fluid level and that's OK. Remove all the quick disconnects, confirm all valve levers are in the neutral position (not detented), including any remote valves you may have. Then drive the tractor (I assume this is hydrostatic). If it drives OK, connect one set of hoses for the loader and see if it works. If it does connect the other hose. If it works it was either a lever in a detent position or a QD not connected. If it drives OK but the hydraulics still don't work, then think about the next step.
Is it possible you're checking the output of the power steering pump and not the hydraulic pump for the hydraulics? Most tractors operate around 2000psi and if you disconnected the high pressure side of the pump that is a heck of a lot of pressure and could be dangerous depending on what you disconnect and how you disconnect it. The water pressure in your house is probably ~50psi, so did it seem like the pressure was 40 times that high? It would be a lot safer and accurate to get a pressure guage and connect it to one of the QDs on the loader and measure the pressure there. It doesn't seem like this would be a filter or a screen problem if it was working fine right up to the moment that it wasn't working fine.
/ Iskei tu2100
Thanks for the reply
it is a gear drive machine it also doesn’t have power steering or quick disconnects on the loader. The loader is a dodgy home made contraption there is just a line going Straight in from the valve block on the tranny and a line going out back into the valve block. See attached photos
the hose on the top right is the return and the one going straight out to the left is the main hose going into the valve block for the loader the one on the bottom right is from the hyd pump
/ Iskei tu2100 #8
I can't think of any more simple things to do.
I'm thinking you need to get a pressure guage with the right fittings on it so you can T it into the system somewhere. Given the way it's plumbed, it's probably easiest to tap into the high pressure line coming into the loader valve body. Does the pump seem to make more noise than it used to? Here's the pressure tester I made, you probably want something similar. Hopefully there's a hydraulic shop where you can get fittings, otherwise you'll have to order online.
/ Iskei tu2100
Thanks for all the input everyone
I ended up disassembling the hydraulic pump to find an o ring had come apart clogging some small channels in the pump. after blowing everything thing out and replacing the o rings shes back up and running now, thanks again everyone
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
2014 Chrysler 200 Sedan (A64557)
2014 Chrysler 200...
2025 SZYMJ Hydraulic Stump Grinder Skid Steer Attachment (A64553)
2025 SZYMJ...
GRILL GUARD FOR MASSEY FERGUSON TRACTOR (A64278)
GRILL GUARD FOR...
2018 Caterpillar 287D Two Speed Compact Track Loader Skid Steer (A64553)
2018 Caterpillar...
2000 Chevrolet Astro Cargo Van (A64194)
2000 Chevrolet...
