Iseki tx1500 name of lifting arms part?
   / Iseki tx1500 name of lifting arms part? #51
Hi Marcel,
I mailed the o-rings yesterday 3/2/2019. That was the first chance
I had to make it to the post office before they closed.
The fellow at the post office said it will take up to
10 days for package to get to Poland. He also said
after they get to Poland he didn't know how long
it would take for the package to be delivered to you.
So let me know if you get them. Also, I used the white
split teflon back up rings and a 70D o-ring in my tractor.
But just for the heck of it I also put a rubber backup
ring in the package as well. I felt that the rubber backup
ring would not hold the main o-ring in the groove. The backup ring
is in there to keep the main rubber o-ring from being
squeezed out of the groove under pressure.
haha i know that everything in Poland is really slow. They are 30 years behind on many things... :) I will let you know.
Can you pm me your address? I want to send you something originally Polish in return...
thx M.
Hi Don, miracles do happen. The parcel already arrived in good state :)
I'm really happy, now waiting for my little iseki to return from getting a FEL installed, then i will open things up again.
once again thanks, really appreciate it.
   / Iseki tx1500 name of lifting arms part? #54
Wow
I didn't think you would get those that fast.
   / Iseki tx1500 name of lifting arms part? #55
Hey Marcel,
I couldn't send a picture through private message so i
stuck one picture here.
Haha looks like someone here used a few bags from postal service to make sure the package was fully secure, and would not break.
Maybe you can use these bags as decoration of your train wreck garage? ;)
Anyway the real treasure is in the wooden box in between. Enjoy! And again thanks.
   / Iseki tx1500 name of lifting arms part? #57
I just checked the container of Iseki stuff and I have the
o-rings for the 3 point piston. I have one o-ring that
is 90 durometer and one that is 70 durometer. The 70 is
softer than the 90 and I used the 70 durometer in
mine. I also have 2 of the split teflon backup rings.
I used 2 of the Teflon backup rings and one of the
rubber o-rings on my piston.
I will mail the 2 Teflon backup rings and the 2
rubber o-rings. You can decide which rubber o-ring
you want to use.
Fxrs55 were the two o-rings 70 and 90 still the same size just different hardnesses just want to know if there is only one size for the TX models
great write up guys good read thanks
Here are a few pictures of valve disassembled.
also a few pictures of the o-rings from my 3 point piston.
it didn't work well until i replaced the 2 o-rings.
One o-ring is a standard type but the other
one is whats called a back up ring. the backup
ring is really a support and it is not rubber.
it is in there to keep the rubber o-ring from
pushing out of the o-ring groove under pressure.
you need to replace those o-rings to eliminate that
problem, then see if 3 point works.
I have to bring this subject back to life. My hydraulics on the tx1500 have given up. Pump is working, all seals and o-rings are new and ok, oil is new.
So it can only be this valve assy. But with all manuals i have, i cannot find anything on the inside of this thing. Does anybody have any better diagram that the one i found on this part?
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
2020 DRAGON ESP...
Hays LT1 Tender (A56435)
Hays LT1 Tender...
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
17101 (A55851)
17101 (A55851)
