Iseki TS1910 or TS1610 owners?
   / Iseki TS1910 or TS1610 owners? #11
Here is another vote for an Iseki board and each Iseki I sell will get an invitation here. We've expanded our parts capability so maybe that will help also. Right Nick?
   / Iseki TS1910 or TS1610 owners? #12
I have a TS 1910 4WD. I enjoy the heck out of it. It just keeps on chuggin.
   / Iseki TS1910 or TS1610 owners? #13
Re: Iseki Owners!!!!
I'm all for Iseki having its own group on TBN. Many newbies like myself will be able get much needed information. I have been accessing TBN for a few months now and have found it to be very informative. Thanks Muhammad and thanks to all of you who have helped so many of us newbies.
Jim
   / Iseki TS1910 or TS1610 owners? #14
I just got this tractor in after the dock strike was over. I haven't had time to do much more than drive it into the shop, but it is the smoothest running and driving tractor I have had.
I am also interested in any info on the TA models anyone has.
I will send a picture in the next post.
   / Iseki TS1910 or TS1610 owners? #15
Picture of TA262
   / Iseki TS1910 or TS1610 owners? #16
TA 210
   / Iseki TS1910 or TS1610 owners? #17
Surge, I was looking under the TA262 today and noticed it had a stamping on the transmission TA210. The information plate on the rear listed several other models in common with the TA 210 and 262. Have you changed the transmission/hydraulic fluid in yours. I swear the fluid on the dip stick at the rear axle smells like 90wt. I had another Iseki that had 3 different places to drain and fill for the trans, rear end and hydraulics. I have been told the Massey 1240 is the same frame as these. The loader bracket will fit anyway. I would appreciate any info you can share on the Isekis we have. You can use the mail option to send direct if you like.
   / Iseki TS1910 or TS1610 owners? #18
Yes, I changed all fluids and filters immediately upon purchase. For the Transmission/Hydraulics/Wet Brakes I used Mobil 424 Universal Hydraulic Fluid and a Napa 1664 Hydraulic filter. I have now purchased my next filter, cross referenced the Napa to a Baldwin BT 260-10 (10 is for 10 micron) which I will install on the next fluid change. I am probably going to go with either Citgo Transgard Universal or Citgo Mystic JT-5 for the Fluid on the next change. My transmission housing is stamped TA210-3 and as far as I can tell only has one large drain plug hole. When I drained it, I took out 5 gallons, which is what it is advertised to hold. It is also located at the lowest portion of the transmission, so I believe it is the proper release point. Believe most recommendations call for a change in the 150 - 200 hour range... Not sure and cannot guarantee the following numbers apply for your tractor as they are from the Japanese Parts Manual for the TA 210... You can run most of these numbers through the online cross reference features of most of the Filter Manufactures web sites....
Iseki Number Napa Baldwin
Air: 1560-103-202-40 6496 PA 3476
Fuel: 1513-102-329-00 3507 BF 717
Oil: 6213-240-001-00 1348 BT 223
Hyd: 1560-515-262-10 1664 BT 260-10
I am currently using Citgo Mystic JT-8 Heavy Duty 10W30 oil in the winter, and 15W40 in the summer. I use Ag Dyed Diesel that I buy at the local Cenex Co-op and add Power Service Diesel Supplement at 3.2 ounces @ 5 Gallons of diesel which is the recommended full strength for anti gelling in the winter and year around centane boost and fuel injector lubrication.
I installed an overrun clutch on the PTO to assist with mowing due to the transmission setup. I'm using a First Choice 5 ft. rear discharge in Blue that matches very well with the color. Thats really about it, I have not had one problem with my tractor. It starts every time and runs great....
   / Iseki TS1910 or TS1610 owners? #19
Thanks so much for the detailed info. Some of the filters I have located are the same as you metion. Some are different. I'll dig a little deeper. I have contacted a couple of Iseki dealers in New Zealand. They say the TA models didn't go there. There is a lot of English instructions under the hood on mine. It must have went somewhere other than Japan.
I got this for resale but I think I will hang onto it until I know enough to sell it and answer the questions a customer would ask.
   / Iseki TS1910 or TS1610 owners? #20
Surge, where did you get your parts manual? I haven't been able to get the later models.
2015 International Durastar 4300 SBA 4 x 2 Water Truck, VIN: 3HAMMMMN4FL510006, Cummins Turbo Die... (A59076)
2015 International...
2014 HYUNDAI Veloster Hatchback (A56859)
2014 HYUNDAI...
PALLET LOF OF WOOD DOORS (A58374)
PALLET LOF OF WOOD...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
2015 CAT D5K2 LGP (A55272)
2015 CAT D5K2 LGP...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
