Iseki ts 1610GLF clutch housing
   / Iseki ts 1610GLF clutch housing #1
Jeek
Iseki ts1610GLF
I have a Iseki ts 1610GLF(the 4wd variant) that had a severely cracked clutch housing. It was repaired but today the welds started cracking and I need a new(un-damaged) one. If anyone has one or knows of one it would be very appreciated!
Thanks in advance!
Info from the parts manual:
Ref No. o30-1-1
Parts Code: 1421-134-0010-1(printed number) or 1421-134-0011-0(someone crossed out the printed number in the book and wrote this one in its place)
   / Iseki ts 1610GLF clutch housing #3
I have parted out a TS1610f. I'll have to check if it has the correct clutch housing. The were 2 styles for the TS1610f. Some had a creeper gear in them.
Excellent! According to my parts manual, there are just the 2wd - GL and 4WD - GLF versions but your knowledge is probably more accurate. Mine does have a High/Low gear selector located at the front of the case, I'm assuming this is the crawler you're referring to.
Continuing a better way to contact me is my email: Bmcsutton1@gmail.com
   / Iseki ts 1610GLF clutch housing #5
Yes The GLF models have the creep.
Okay, did you get a chance to check the parts unit you've got? does it have the creeper
   / Iseki ts 1610GLF clutch housing #7
I've parted out 3 of them, but guess I sold 2 of them. I know I had one with the creep, but the one I have left doesn't have it.
That's unfortunate. Is the one you have left still a 4wd? or just 2wd?
   / Iseki ts 1610GLF clutch housing #9
2wd
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
1269 (A50490)
1269 (A50490)
2023 JOHN DEERE 8R310 LOT NUMBER 203 (A53084)
2023 JOHN DEERE...
Freeman Bros 200 Gallon Fuel Tank (A51573)
Freeman Bros 200...
2018 New Holland T8.350 MFWD Tractor (A53342)
2018 New Holland...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
