Iseki ts 1610GLF clutch housing
   / Iseki ts 1610GLF clutch housing #1
Jeek
Iseki ts1610GLF
I have a Iseki ts 1610GLF(the 4wd variant) that had a severely cracked clutch housing. It was repaired but today the welds started cracking and I need a new(un-damaged) one. If anyone has one or knows of one it would be very appreciated!
Thanks in advance!
Info from the parts manual:
Ref No. o30-1-1
Parts Code: 1421-134-0010-1(printed number) or 1421-134-0011-0(someone crossed out the printed number in the book and wrote this one in its place)
   / Iseki ts 1610GLF clutch housing #3
I have parted out a TS1610f. I'll have to check if it has the correct clutch housing. The were 2 styles for the TS1610f. Some had a creeper gear in them.
Excellent! According to my parts manual, there are just the 2wd - GL and 4WD - GLF versions but your knowledge is probably more accurate. Mine does have a High/Low gear selector located at the front of the case, I'm assuming this is the crawler you're referring to.
Continuing a better way to contact me is my email: Bmcsutton1@gmail.com
   / Iseki ts 1610GLF clutch housing #5
Yes The GLF models have the creep.
Okay, did you get a chance to check the parts unit you've got? does it have the creeper
   / Iseki ts 1610GLF clutch housing #7
I've parted out 3 of them, but guess I sold 2 of them. I know I had one with the creep, but the one I have left doesn't have it.
That's unfortunate. Is the one you have left still a 4wd? or just 2wd?
   / Iseki ts 1610GLF clutch housing #9
2wd
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
Gleaner R50 Combine (A50514)
Gleaner R50...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
Land Honor Quick Attach Vibratory Plate Compactor (A50514)
Land Honor Quick...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
