iseki ts 1610
/ iseki ts 1610 #1
danny11b
longtrac 528, long 610.allis 5030.5040,5045.mitsubishi mt2001.allis 185,caseinternational 234, white 2-105
there is a lever that has l-m-h. I assume it means low, medium, and high. I can't get it out of m. What do I need to do?
/ iseki ts 1610 #2
Do not force it. If you have a service manual or a diagram parts manual, you might be able to open up the area to make adjustments and/or repair.
/ iseki ts 1610 #3
With the tractor at a dead stop you can try depressing the clutch and moving the lever. If it still won't move you can try moving the tractor forward or back a bit then do it again. If there is pressure against the gears they may not slide easily. Do not force it. If you do manage to get it out of M you may have trouble shifting into L or H. You essentially have three gears with a neutral between each. If you do not fully engage the selected gear the tractor will be in neutral and will not move.
/ iseki ts 1610
thanks to the replys
/ iseki ts 1610 #5
There is a ball with a spring to keep the lever in the position you want it. It may be froze. If this is the problem, Tap the lever lightly either way to get it loose,
/ iseki ts 1610
thank you
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
Brent 420 Grain Cart (A63688)
Brent 420 Grain...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
