ISEKI TA210F
/ ISEKI TA210F #1
HANOVER
beaverdam,va
ISEKI TA-230F
Hello, I just became a new owner of an ISEKI TA210f 4x4 tractor. I basically bought it because of good comments from this forum. however any additional information anyone can give me would be greatly appreciated. I also bought a FIRST CHOICE finish mower. (5'ft.) Look forward to hearing from you.
Thanks.
/ ISEKI TA210F #2
Rainbow Dist. has a parts manual for it. I have a TA215 and am waiting for one for it. I would like to compare them sometime. I haven't been able to tell any difference in the two so far. I did see a picture of a TA210 with the exhaust going out the hood. Mine goes out the left side down low.
/ ISEKI TA210F #3
I just picked up a TA210. Nice tractor. Exhaust goes out the hood. Tach doesn't work. It's electronic, no cable. Have to check it out this weekend. I might keep this one.
/ ISEKI TA210F #4
I sold greys for 4 years. The TA215 is the one I kept when I quit. Mine has a mechanical tach. It wouldn't work when I got it. The guts of the tach had frozen from setting. I took It all apart and loosed the works with good old PB Blster and it has worked ever since. I had to JB Weld the gear back on it's shaft but it is still ticking. Can we figure out if the TA210 came before or after the TA215? I have a Massey 1125 owners manual, the TA215 is identical except for a switch or two and an electric PTO clutch.
/ ISEKI TA210F #5
The TA210 was manufactured in 1986 and 1987. The TA215 was manufactured from 1988 to at least 1990. These years are also true for the other TA__0 and TA__5 models.
/ ISEKI TA210F
OK, like I said. I just bought the tractor. It isn't a TA-210F /forums/images/graemlins/blush.gif
I found the ID Plate which has TA-230F as the model. Sorry for the confusion. I appreciate the responses that I received however. Didn't mean to waste anyones time.
OK, does anyone have any information on the ISEKI TA-230F tractor? (Now that I know what the heck I have.) There seems to be a module under the seat that has two toggle switches & fine tuning adjusting pots or something. Can anyone tell me what these are for? Thanks in advance.
HANOVER
/ ISEKI TA210F #8
What does it say on the fender? Iseki uses the same chassis for several models. The TA270 I had had TA210 on the chassis.
/ ISEKI TA210F
The fender has Landleader 230 on it. The dealer that I bought the tractor from said that the Massey-Ferguson model MF-1230
is the same tractor. I hope so. The japanese directions written on the panels and fender is obviously of no help. thanks for your reply.
/ ISEKI TA210F #10
I think you will find that it is closer to a Massey 1125. I have a Massey 1125 manual and everything matches my tractor. Yours will fall in between the 1125 and the 1140. The 12XX series is newer than ours.
/ ISEKI TA210F #11
I just assumed the tach was electronic, because I didn't see a cable going in. It's a skinny little thing that looks like another wire. My son took dash apart today and found the cable barely hanging onto the tach. He reconnected it and now it works great. My wife wants this tractor. Looks like a keeper.
/ ISEKI TA210F #12
I worked my TA215 all weekend. It is a joy to use. I put a new seat with arm rest on mine. The original had all the padding gone.
/ ISEKI TA210F #13
So, any idea when the TA 262 was mfg'd? Early 90's?
I'm looking at one tomorrow night and trying to get as much info on them as possible.
Thanks for the help guys (and gals).
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
Deere 210G LC (A64126)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2020 FORD F-350 (A65643)
2020 FORD F-350...
John Deere (A64126)
John Deere (A64126)
