iseki stuck in 2 gears
/ iseki stuck in 2 gears #1
izekis
any ideas . my iseki 17hp mini tractor is stuck in fowd and reverse gears together . will cut off engine when clutch left off . where do i start dismantling.
/ iseki stuck in 2 gears #2
If there is a top cover you can take off the transmission where the gear shift is try removing it. The shifting forks should be exposed and you might be able to see where the problem is and move things into the netural position.
Randy
/ iseki stuck in 2 gears #3
Some tractors do this now and then. If there is a top cover remove it and gently jiggle the slider gears. It may come loose and be just fine. I had a MF135 that I had to do this with a few times until I learned the proper way to change gears.
KBH Tank Trailer (A63118)
KBH Tank Trailer...
New/Unused Pallet of 8 Binders and 16 Chains (A61166)
New/Unused Pallet...
2012 Ford F-450 4x4 Altec AT200A 30ft Bucket Truck (A61568)
2012 Ford F-450...
Ford BS454C Tractor with Box Blade and Sweeper Attachment (A61567)
Ford BS454C...
UNUSED WOLVERINE RCR-12-84W 84" HYD ROCK RAKE (A62131)
UNUSED WOLVERINE...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
