Iseki SR1100CD tiller
   / Iseki SR1100CD tiller #1
Witold
ISEKI TX2160
Hi
I am trying to work out how to mount the tiller on my Iseki tx2160. I can see that it does go on a 3pt linkage.The 2 short link arms go directly onto the lift arms but how do the 2 lower mountings attach to the tractor? Any drawings or pictures would be a great help.
   / Iseki SR1100CD tiller #2
Hi
Best to ask in the Iseki section of TBN, those people know much more,
   / Iseki SR1100CD tiller #3
Hi
Hi,
Posting in this section of the forum is perfectly fine. I found a picture online, maybe this will help you out:
   / Iseki SR1100CD tiller #4
Hi,
Yes, this model has the short and quick lift rice-paddy setup. So the lift arms attach directly to the tiller. There are no lower 3-point arms. My Yanmar is setup the same way when using the Yanmar tiller. This is the common Japanese method for tiller setup.
This tiller would need the very short PTO-shaft too. It would have the double knuckle universals.
   / Iseki SR1100CD tiller #5
This Iseki does use the 3-point lower arms with the rotary tiller. Let's not focus on that, look at the very very very short PTO drive shaft starting at the 1:15 mark.
   / Iseki SR1100CD tiller #6
That's a different tiller than the OP though.
   / Iseki SR1100CD tiller #7
duh, exactly. I said, to only look at the PTO drive shaft.
The images you had posted have the safety shield covering the PTO drive shaft.
   / Iseki SR1100CD tiller #8
I would've thought that a PTO shaft would have been pretty self explanatory, since it can really go in one place on the tractor. 🙂
(4) 225/65R17 USED TIRES (A58374)
(4) 225/65R17 USED...
Freighliner Tender Truck (A56436)
Freighliner Tender...
8' ALL HYD SCRAPE BLADE, 3PT (A52708)
8' ALL HYD SCRAPE...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
CAT Chassis Only (A59076)
CAT Chassis Only...
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
