Iseki / Massey
/ Iseki / Massey #1
kayssupply
Platinum Member
S Illinois
Iseki TA 207
I am trying to match an Iseki built in 2003 with a Massey CUT. It has 24 engine hp. 12 speed shuttle shift. Does anyone know what Massey was built in 2003? The 12XX series is close but the data I have only goes to 1999.
/ Iseki / Massey #2
Very nice looking tractor. What is the model number? I also wish I had more data on the Masseys...
/ Iseki / Massey #3
I have manuals for the 1200s and the 1400s. What is the engine model?
/ Iseki / Massey
It is a TA207. I have had 230,250,262,215 and 270. This is the newest. It has 03 on the rim. I am assuming that it is a 2003. I'll check the engine code this PM. So far the biggest difference I have found in the different TAs is the body mounts that are different but can be interchanged. I swapped a later model set on the TA270 to make a 1250 loader fit. I have pretty much matched the TA270 to an MF1140. The wheels and tires are my addition, thanks to Hey Machinery.
/ Iseki / Massey #5
So amongst all those models (TA207, 230, 250, 262, and 215), do you think they will all take the same MF1250 mount that you installed for your Bush Hog FEL? As per your advice, I just installed the MF1250 Koyker mount kit on my TA270 and it worked out great. I am just curious if I could the same with the other models.
/ Iseki / Massey
It has an E3AG1 prefix. It also has a 61.5" wheelbase, which doesn't match a 1240. The 1240 is the right hp but it has a 63.6" wb.
/ Iseki / Massey #7
I found something. The Massey 1125 used a E3AG1, then it had a suffix of Bo4K. It is also a 24 horsepower. I don't know what the suffix stands for but maybe that will help. I have the engine specifications if you need them. This manual was printed August 1998.
/ Iseki / Massey
I have that manual. I am going on the info that the 03 on the wheel means 2003. The wheel date has been correct in the past, but the other poster says that it isn't this time. So far the 1240 could be a newer version of the 1125 but the wheel base doesn't mach this tractor. Is there a 14xx series with 24hp and a 61.5" wb?
/ Iseki / Massey #9
Sorry that I don't have time this morning to look it up. I have to meet an 18 wheeler to get 90k baby chickens. I will try to find it this afternoon.
/ Iseki / Massey #11
The closest thing that I could find was a
MF1423 with a 59.9 wb and 23.3 hp.
Then it jumps to a
MF1428v with a 65.6 wb and 28.4 hp.
MF1429 with a 68.5 wb and 28.4 hp.
MF 1431 with a 65.6 wb and 33 hp.
Comparing the picture of your tractor to a 1423. The 1423 has a hump to step over on the floor and yours doesn't.
From comparing all the pictures I have of 1200s and 1400s, I don't think that yours compares to any of them. I think that is is more than likely a tractor from the 1100 era.
/ Iseki / Massey
Maybe it is 93 instead of 03 on the wheel. I 'll look closer. Thanks
/ Iseki / Massey #15
Numbers on the wheel will have no reference to the year production of the tractor. Just and FYI. Enjoy your tractor. they are well built.
2011 Chevrolet Express 2500 Cargo Van (A64556)
2011 Chevrolet...
2022 EZ-GO ELITE...
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2016 INTERNATIONAL...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
12ft. 24 Gauge R Panels (A65640)
12ft. 24 Gauge R...
County Line 4' 3-Pt Rotary Mower (A66408)
County Line 4'...
