Iseki Landleader 210
/ Iseki Landleader 210 #1
LRUSSBLACK01
Hi, I’m UK based but the sites and dealer here is struggling to help me in regards my Iseki Landleader 210 as it’s a grey import. I’m seeking a pdf of the owner/maintenance manual if anyone has one or can direct me to a site that does.
Also can anyone help advise in regard engine lubricant volume and oil viscosity plus filter part numbers for engine and transmission fluid?
The dipstick appears very non-user friendly. It unscrews but appears obstructed by pipe work above to extract it. Is this standard?
Any help or support will be greatly appreciated.
By the way, this is a great piece of kit. I just want to look after it.
Thanks in anticipation
/ Iseki Landleader 210 #2
It should be a great old tractor. Tractors of that vintage generally used a 15W-40 diesel rated oil. If you pull your oil filter your local auto parts place should be able to measure threads and seal diameter for a replacement. The same should also hold true for the hydraulic filter. Many tractors of that vintage had a filtering screen in addition to or instead of a hydraulic filter.
