Is this worth $75?
/ Is this worth $75? #1
Jarrett
Holden, Louisiana
Kubota L3130DT
I found a local classified ad for this 6' grader box. The guy wants $75 for it. As you can see from the picture it needs some welding done to make it useable. It could use even more work to make it stronger etc. I can do all of that myself. It's obviously a homemade job. Would you give $75 for it?
/ Is this worth $75? #2
I wouldn't pay 75 bucks with that broken weld.
/ Is this worth $75? #3
I'd probably pass on this one myself. 75 bucks buys me most of the material to build one , heck it might even turn out better to boot. But thats just my opinion.
I guess if you were willing to replace that angle piece up front with square tube as it should be, and repair the 3 point doodad up top it might work pretty well. I'd probably be able to destroy somthing like that in short order, but luckily I have 2 box blades in reserve so im ahead of the game.
Now, ifn you plan on makin it into a bar-bq or smoker or sumpin like that, nother story entirely... :p
/ Is this worth $75? #4
I'm with Roy. It looks quite flimsy and for the time to fix it and the gauge of the metal I'd pass. Buy one that will work well and last.
/ Is this worth $75? #5
20$
Soundguy
/ Is this worth $75? #6
He could pay me $20 to haul it away for him...
Looks like someones homemade box scraper experiment that got hung up and the design failed. It would need a stronger replacement cross beam(box or round tube) for that bent angle iron one. I would also add a second tab for the lower 3PH pins, outboard of the originals(lower arms go between the tabs and common hitch pins are inserted) like the toplink attach is. This spreads the stress out.
That looks like the broke weld ripped out the tube wall. Probably too thin a tube stock or too much weld penetration/melted tube. The fact that the lower tabs and pins appear straight says it didn't take much force to torque this thing. The workmanship looked pretty good, just the wrong materials for the job.
If the blade and sidewalls are still straight, offer him $10 explaining that the whole crossbar and 3PH attach will have to be replaced with appropriate materials. It probably dosn't have a cutting edge and is just mild steel. If it is not re-enforced or at least 3/8" thick, pass alltogether. If it has a bolt on cutter, that is good. If it dosn't and is only 1/4" as it looks to be, you could weld on a piece of 3 to4" X 1/4" strap down there to re-enforce it on the edge and weld harden it, but again, that is a lot of work to make it right.
/ Is this worth $75? #7
Remodeling is always more work than building new. I do not think that it is worth the effort. If you could use the metal to build what you want, then fine but otherwise why?
JMO
mike
/ Is this worth $75? #8
Nope--have to pass. Failed design homemade out of the wrong stuff for the job. Too light a steel to scrap or to salvage. Be patient & something better will come along, but probably a little more $ than that.
/ Is this worth $75? #9
Yep.. I found a good used oxen brand boxblade onthe side of the road for 100$. It needed a little torch and sledge work on one spot.. but has been a jamb up unit for the last 8 years now..
soundguy
/ Is this worth $75? #11
I agree with the others. It's not that $75 is allot of money, but that thing looks to be poorly built with the wrong materials. Keep your eyes open and you'll see that box blades and other implements show up all the time.
craigslist: san francisco bay area classifieds for jobs, apartments, personals, for sale, services, community, and events is my current favorite source for good deals. I check it every day for what's for sale in East Texas.
Classifieds - Classified Ads - Advertising - Used Cars - New Cars - Homes for Sale - Real Estate has had some great deals, but you have to be quick. It comes out Thursday morning and I've missed on a few things because I was too late.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices isn't what it used to be for good deals, but from time to time they come along. Especialy if it's listed in an odd area. If I'm looking for something specific, then I do a search of everything on ebay for it. You'd be suprised to see where people list things!!! This is how I got my laser level!!
And of course, driving the back roads and taking different routes has worked too. I drove to Dallas to look at a dump truck one time. The truck wasn't what I wanted, but on the way home, I took a different route. Sitting along the highway was the truck I ended up buying.
Auctions haven't worked out for me yet, but I haven't given up on them either. Just be sure to know what it's worth brand new before going there as I've seen items sell used for more then you can buy them brand new!!! I was looking at 16 foot two axle trailers and they were selling at or even above $1,000 at the auctions I went to. I bought mine brand new in perfect condition for $950 from a trailer builder here in town.
Good luck,
Eddie
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
1989 STE 307 SS 4 Comp Non Insulated T/A Chemical Tanker Trailer (A64194)
1989 STE 307 SS 4...
213078 (A64276)
213078 (A64276)
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2010 CATERPILLAR 120M AWD MOTORGRADER (A63276)
2010 CATERPILLAR...
